Old Nov 22nd, 2004, 11:07 PM   #1 (permalink)
redbak
Angry Electrical System Problems
92 Sentra 1.6L. The car was dying at night and I noted the alternator wasn't charging. At the following items stopped working;The Dash lights, radio, blinkers, heater, wiper, AC, Stereo, key wont come out of ignition, brake lights, hazard lights, gas gauge, power mirrors, wipers, dome light.
I replaced the Alternator thinking the battery benig drained would halt electrical circuits such as lights and such. After replacing the alternator charged the battery and the car starts, but none of the above items work.
The head lights do work though.
I pulled All fuses in the dash, by the battery and all do not visibly appear blown. Any Ideas?
redbak is offline   Reply With Quote
Old Nov 23rd, 2004, 11:20 AM   #2 (permalink)
toolapcfan
Your electrical friend
toolapcfan's Avatar
There's a fusible link right off off the battery, it's a black connector looking thing. See if that's blown. What probably happened was when your alternator was on it's way out, it cuased a current overload and blew that fusible link.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Nov 23rd, 2004, 11:31 AM   #3 (permalink)
redbak
I saw the fuse link and pulled it apart, but I couldn't tell if it was bad, how can I determine if its blown? Thank you for taking the time to reply.
Old Nov 23rd, 2004, 01:34 PM   #4 (permalink)
redbak
That was the problem, the fusablelink was blown. I replaced it and it blew right away. Sounds like something is grounding out somewhere.
Old Nov 24th, 2004, 01:26 PM   #5 (permalink)
toolapcfan
toolapcfan's Avatar
Do you know how many amps that fusible link is rated at? The reason I ask is because your radiator fans and ABS have their own 30A fuses, so if either of those were causing the problem, they would blow before the fusible link would if it's higher than 30A. By that same notion, the rest of that circuit has even samller fuses. So I'm guessing it's something with your alternator.
Rob '93 SE-R
Halo Light Electrical Problems! Seth? Help? oaktreet New Member Forum 9 Jun 26th, 2004 08:59 AM
Newbie with charging system problems! 240SXKID General 240SX/Silvia/S12 200SX 6 May 17th, 2004 03:26 PM
Sound System Problems Nacho-Mojo Audio 2 May 8th, 2004 08:52 PM
Need Help! Electrical Problems! SoMissSentra B14 95-99 chassis 3 Oct 11th, 2002 11:12 PM
