Old Nov 14th, 2004, 12:49 PM   #1 (permalink)
toastedzergling
Problem with tranny oil change on 93' Sentra
I think the manual transaxle fluid on my 130k mile 93' sentra has never been changed, so I read the Haynes repair manual, I bought 4 quarts of redline MT-90 and I crawled under the car, well I find out that the fill plug is a square hole, my 3/8" ratchet is a perfect fit however it won't budge no matter how hard I try, to make things worse the drain plug is larger than my 1/2" ratchet, I think it's around 5/8" (also a square hole), do I need a special tool to unscrew these suckers?
toastedzergling is offline   Reply With Quote
Old Nov 15th, 2004, 12:01 AM   #2 (permalink)
oljunkie15
Send a message via AIM to oljunkie15
yes there are square drivers made for these types of plugs. however usually you can get away with using just a ratchet to get it out. if the plug is really stuck (as if someone used sealer on pipe thread) then you will most likely need the tool so that you dont round out the hole. remember that it is pipethread so when you replace the plug you do not need to use sealer.
oljunkie15 is offline   Reply With Quote
What weight of oil do I need for an oil change? david328ci GA16DE 1.6L Engine 15 Aug 7th, 2004 01:32 PM
83 Sentra, E16, Weird tranny problem rhlimited E/CA-Series & GA16i Engines 6 Jun 23rd, 2004 02:30 AM
82 nissan SENTRA problem with auto tranny joker73 New Member Forum 2 Jun 19th, 2004 11:41 AM
Oil Pan Removal 93 Sentra 1.6L...Help Please!!! simspektor GA16DE 1.6L Engine 4 May 22nd, 2004 09:35 PM
Oil Choice/ Oil Filter/ Change Intervals BigRed Truck & SUV 19 Jul 24th, 2003 09:40 PM
