Old Jun 2nd, 2004, 08:09 AM   #1 (permalink)
omnimedia
omnimedia's Avatar
Send a message via AIM to omnimedia
Angry wierd vibration not transmition not brakes
when i accelerate or slow down everything is fine. but when i hold the gass @ say about 40-60 mph it vibrates. not in the stearing wheel but a vibration in the engine compartment. i just got this car it kinda a lemon this dealer skrewed me on it. one thing is that it leaks tranny fluid so i had it checked out @ the transmition shop they said the trannys cool and it shifts when it supposed to. the motor and tranny mounts are about 50/50. the brakes are fine. it been up on 3 lifts but this ones a mystery to everyone. has anyone else had this vibration?
1990 b12 2door red
1994 b13 4door blue metallic
orlando, FL home of the sr20 swap
omnimedia is offline   Reply With Quote
Old Jun 2nd, 2004, 08:37 AM   #2 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Two things to try:
- Pull the spark plugs and examine them. If one is diffeent from the others it indicates a problem in that cylinder.
- While the plugs are out, check the compression in each cylinder. They should all be the same. If one is low, that could be your problem.
Lew
lshadoff is offline   Reply With Quote
Old Jun 2nd, 2004, 11:22 AM   #3 (permalink)
Cali SE-R
Do It In A Datsun!
Cali SE-R's Avatar
Send a message via AIM to Cali SE-R
I just had a vibration problem in my car, if the vibration feels like it is coming from one side of the car more than the other, then it might be that your wheel bearing is out, I thought it was my brakes too, and if it is the bearing, get it replaced fast, because I messed up my hub in the process for waiting to long, hope that helps you out!
"Wow, your car looks awesome in my rear view mirror!!"
SHIFT_I SAID SHIFT, DAMN IT!!!
http://www.cardomain.com/id/71_510
Cali SE-R is offline   Reply With Quote
2001 Sentra rear brakes adjustment? bonestocksentra Suspension & Brakes 8 Aug 11th, 2004 04:34 PM
strange noise from brakes??? 95truckin Truck & SUV 1 Apr 19th, 2004 03:54 PM
Fast Brakes High Performance Big Brake Kits AZ_TURBOSE Group Buys 0 Feb 11th, 2004 02:57 PM
help brakes are dead. desparate, bled em to death. nissanpimp Suspension & Brakes 2 Nov 13th, 2003 08:23 AM
brakes need to be pumped several times until they are stiff? Cullam3n Suspension & Brakes 4 Oct 1st, 2003 04:26 PM
