Old Jan 10th, 2004, 11:16 PM   #1 (permalink)
Cuban_B_93_XE
Cuban_B_93_XE's Avatar
BRAKE Light ON: Stays on
The BRAKE light on the dash remains on. Is it anything with the brakes or my WW Fluid?
Tearin Up Voorhees, NJ
My Roomate is RUSSIA
http://bicweb.nuclearfallout.net/CubanB.gif
Cuban_B_93_XE is offline   Reply With Quote
Old Jan 10th, 2004, 11:18 PM   #2 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
check the fluid in the resevoir tank for the brake fluid, if it seems ok....*this is a long shot*, but put the key in the ignition and turn it to the ON position and see what kind of lights turn on the dash, see if your battery light works(because if it doesnt, it means it probably burnt out) and it might be that u have an alternator problem but that is just a long shot.
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Jan 11th, 2004, 12:41 AM   #3 (permalink)
tomd
tomd's Avatar
Send a message via AIM to tomd
mine did that too, was full of brake fluid and all, ended up just unplugging the sensor on the master cylinder, and now its off, guess the sensor just went bad or somethin?
91 Sentra E
205/50R15 Falken 502's on 15x7s
tomd is offline   Reply With Quote
Old Jan 11th, 2004, 01:24 PM   #4 (permalink)
Cuban_B_93_XE
The BRAKE light turns on and off. But its usually on longer than it is off.
Old Jan 11th, 2004, 03:07 PM   #5 (permalink)
tomd
tomd's Avatar
Ah yes, i remember now, mine would turn off during acceleration only, but kept getting worse and would only flash after a while...Might go take a look at the sensor in the master cyl today.
91 Sentra E
Old Jan 11th, 2004, 05:54 PM   #6 (permalink)
scrub brush
In class
scrub brush's Avatar
Send a message via AIM to scrub brush Send a message via Yahoo to scrub brush
Check your parking brake cable. That was the problem with mine. It seems it would stick and the light would remain on. You might hafta get under the car and check. I ended up taking the drums off, cleaning the gunk and lubing the cable.
Chief Engineer for Club MoFo
Can I put a turbo in my non-turbo? Yes. The trunk is quite large.
Can I put a Supercharger in my Z31?Yes. You can probably put it next to the turbo.
Can I put a Z32/newer 300ZX/VG30DETT in my Z31? This one is iffy. You'd have to disassemble it to get it in the trunk.
scrub brush is offline   Reply With Quote
Old Jan 12th, 2004, 10:22 PM   #7 (permalink)
Eric Rodrigues
Eric Rodrigues's Avatar
Sounds kinda crazy but it may be your alternator going out. This happened on my first sentra id get it tested
93' B13 SE :idhitit:
Eric Rodrigues is offline   Reply With Quote
Old Jan 13th, 2004, 06:23 PM   #8 (permalink)
Cuban_B_93_XE
Shit, this is bad. If i get a capacitor for the amp i have will it help. My amp is 70 w and about 3 yrs old.
Old Jan 13th, 2004, 06:26 PM   #9 (permalink)
B11sleeper
Datsun Guy
B11sleeper's Avatar
Send a message via AIM to B11sleeper
if by a 'cap' you mean a stiffening capacitor, probably not, 70 watts isn't going to make electrical problems.
I think i had the brake light coming on intermittently, i replaced my master cylinder and it stopped doing that, but also the hand brake could make the light come on.
1981 datsun 210. nothing interesting here...
B11sleeper is offline   Reply With Quote
Old Jan 13th, 2004, 07:20 PM   #10 (permalink)
darufone
darufone's Avatar
Cool
As mentioned earlier, check the brake cable and the switch under the actual e-brake handle. My light stays on also, but I can see where the switch is actually holding the e-brake from resting flat, which seems to be a cable problem. Too cold to check right now...<10 degrees in NYC.
darufone is offline   Reply With Quote
Old Jan 13th, 2004, 07:32 PM   #11 (permalink)
tomd
tomd's Avatar
Try this, its what i did, and my lights off now =P Unplug the connector on the Mas Cyl, but i can't be liable if you never check your brake fluid, i'm underhood a lot so i check it often.... And the light will still come on w/ the parking brake and such....
91 Sentra E
Old Jan 13th, 2004, 07:47 PM   #12 (permalink)
NismoXR
Nissan Fanatic
NismoXR's Avatar
Send a message via AIM to NismoXR Send a message via MSN to NismoXR
Hey Maybe you have too much brake fluid. What your describing exactly happened to me. I had to take some brake fluid out and the light didn't come back on. It did come on and off like your describing.
Pedro
My Car
NismoXR is offline   Reply With Quote
Old Jan 15th, 2004, 02:36 AM   #13 (permalink)
Masa
Masa's Avatar
Send a message via AIM to Masa
The brake light on my car started doing this a while ago. I checked the brake fluid and it was good. I decided it must be the cable only so I figured it wasn't a big deal. Now on top of having the brake light on, the battery light comes on as well while I press the gas. I'm guessing it must be the alternator like some of you said. How can a dying alt be the cause of the brake light coming on? Just wondering.
HS headers, PR CAI, custom exhuast, GC coilovers, KYB-AGX struts, Stillen front strut brace, NX 2K sways, RSTB, Konig Imagines, PIAA super plasma H4s, Stillen BK, no stickers. My car
Masa is offline   Reply With Quote
Old Jan 15th, 2004, 12:22 PM   #14 (permalink)
toolapcfan
Your electrical friend
toolapcfan's Avatar
Why do people repost the same shit they already said?
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Jan 19th, 2004, 07:08 AM   #15 (permalink)
1badnx
1badnx's Avatar
Send a message via Yahoo to 1badnx
The answer to this is more than likely your e-brake actuator button sticking. all this does is turn on that light so you know to disengage the brake before trying to drive. If pop the center console out and clean it up the problem will subside. My car started doing this too. This year when it got really cold out. I popped the console and found dried and frozen orange soda all over. cleaned that all up and the light went. FYI upon investigation found out g/f had dumped a biggie size orange pop alll over and didn't tell me. knew i would be hot cause nobodi supposed to eat or drink in my car.
B13 all day, everyday!
1badnx is offline   Reply With Quote
no brake light when tail light is on SEv6 New Member Forum 5 Nov 7th, 2003 08:43 PM
brake light wont go off pearsont74 Truck & SUV 2 Jul 31st, 2003 11:12 AM
brake light on dash soiledxdesire B14 95-99 chassis 3 Apr 17th, 2003 01:57 PM
trunk 3rd brake light? superfro86 Cosmetic Mods 3 Mar 17th, 2003 06:32 PM
hand brake light stays on!!! vividance S13 240SX 1989-1994 2 Oct 15th, 2002 06:33 AM
