Old Dec 31st, 2003, 12:02 PM   #1 (permalink)
92sentra
Question Help! Engine suddenly lost hi rpm !!!
I have a 92 sentra e with 135k on it. Car was running fine. Parked it in the garage for 2 days. Went back out, completely dead. Ok, I think, need a new battery, current one is 5 YO. Charge up the battery, car starts right up, start off to Sears for a new one, and suddelnly, the car starts bucking like I never drove stick before??!! Went into second, starts off ok, then same thing. Happens though all 4 gears (Can't hit 50mph in 4th!). Turn car around, get back home. With car in neutral, engine gets to certain RPM, then back down (E's have no tack, don't know exactly what rpm, but not very high). So I rule out tranny as the problem. Check the plugs, they are fine. The problem happens at same rpm, so too exact to be a clogged fule filter, right? Please help, I love this car, but I am not dropping big bucks on expensive repair!
92sentra is offline   Reply With Quote
Old Dec 31st, 2003, 12:04 PM   #2 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Sounds like a MAF problem...
05 Frontier SE CC 4x4 (6spd)
Old Dec 31st, 2003, 12:07 PM   #3 (permalink)
Harris
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
It could be worse. Here is a list of things, of which one or more could need fixing/replacing:
1) Fuel lines
2) Vacuum Lines
3) Air filter
4) MAF
5) Distributor (very unlikely, but not impossible)
Let me ask you this, does it feel like the car stops you from going above a certain rpm, that is, does it knock you down soon as you hit a certain rpm? If so, that could just be the distributor thats gone.
Good luck.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline   Reply With Quote
Old Dec 31st, 2003, 12:45 PM   #4 (permalink)
92sentra
1) Fuel lines
2) Vacuum Lines
3) Air filter
4) MAF
Good luck.
Yes, exactly! COULD THE DISTRIBUTOR have been damaged during the battery recharge? And not to sound like a complete dumbass, but what is a MAF?
Old Dec 31st, 2003, 12:48 PM   #5 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Airflow meter.
Old Dec 31st, 2003, 12:56 PM   #6 (permalink)
92sentra
Thanks , guys. I'll let you know how it works out! Have a Happy Nissan New Year!
Old Jan 1st, 2004, 09:58 AM   #7 (permalink)
cronkbogey
cronkbogey's Avatar
I agree that it might be the MAF. Not too expensive or difficult to replace yourself. I think mine cost $70. Also check to make sure the grounding wire is clean and tight (I think mine is on\near the battery tray holder). Once I had the same problem as you and thought my MAF was bad. Turned out that that black wire was loose. No harm in checking. Good luck.
ONWARD TO VICTORY!...or at least survival.
cronkbogey is offline   Reply With Quote
Engine knock in 2003 at 1800 RPM ?? sjm_mak A33 2000-2003 Chassis 15 Jun 30th, 2004 09:13 PM
manuel with spec v no1d B15 2000-2006 49 Mar 8th, 2004 04:44 PM
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 10:09 AM
SPECS to Compare Compacts sentravis B14 95-99 chassis 3 Oct 26th, 2003 08:52 PM
I'm going to Ennis 7SPEED Dallas Nissan Enthusiasts 39 Jul 1st, 2003 12:24 PM
