when i first start the car and drive the power steering squeals when i even barely turn the wheel, and it pulses and squeals as i make a full turn...after the car has been running for a while it works fine...but if it has been sitting are is cold out it gets really bad and really embarassing to park or start driving in a parking lot....everyone is looking.....
what could it be??...and yes it has fluid in it.
TIA
NEED TURBO PARTS...GOAL....500WHP!! PLEASE HELP NEEDY SPEED FREAK WILL ACCEPT ALL DONATIONS :thumbup:
Mine is doing the exact same thing. Didnt start till it recently dropped to 0F outside here in indy.
Anyone gotta fix for this? I sprayed belt dressing on the pulley.. it quited it down for a few, but still does it.
Im pretty sure if its pulsing (which mine does too) then the belt is slipping.
The squealing noise is almost always attributed to the belt(s).
If there is a groaning noise when turning the wheel, you're out of power steering fluid and need to fill it up.
I think those who are having the squealing noise coming out of their belts should check for any moisture on the belts. I'm almost positive it has everything to do a mix of moisture and the kind of weather out there.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
Mine has been doing the same thing lately, what is the best way to completely drain the PS system. Are you guys running ATF like the repair manual states (at least that is what my d@mn Haynes manual says?)
