Old Aug 11th, 2003, 04:49 PM   #1 (permalink)
Bluesr20
Send a message via MSN to Bluesr20
Exhuast Pipe Sizing for Jdm Engine
I have a 91 Nx 2000, with a JDM high compression engine, i have intake, advance timing,no cat, and im goin to be putting the jdm equal length exhaust manifold on very soon, What size of exhaust should i be gettin, 2.25 or 2.5?
Who needs drugs and alcohol when you can drive your Nissan....
Bluesr20 is offline   Reply With Quote
Old Aug 11th, 2003, 04:56 PM   #2 (permalink)
bahearn
bitter old man
bahearn's Avatar
The bigger the better as long as you don't have interference problems.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Aug 11th, 2003, 05:57 PM   #3 (permalink)
fugiot
Farms suck!
fugiot's Avatar
Bigger is NOT better for N/A applications. You will lose tons of low-end power if you have no backpressure. I'd suggest between 60mm and 70mm. For N/A SR20's I'm pretty sure that 60mm is ideal but I'm not completely sure. Only go as big as you can if you're also going turbo. Check HKS and Greddy exhaust systems. I'm not sure if they offer a bolt-on exhaust for the NX2000 but you might be able to get an SE-R one on there with some fabrications.
My SE-R cardomain page!!!
You got SE-RVED!
fugiot is offline   Reply With Quote
Old Aug 11th, 2003, 08:53 PM   #4 (permalink)
jdmser
jdmser's Avatar
i have that engine and i am running 2.5 and it works great top and bottom end.
JDM high compresion motor,I/H/E
V-TEC THIS!
jdmser is offline   Reply With Quote
Old Aug 11th, 2003, 09:11 PM   #5 (permalink)
fugiot
Farms suck!
fugiot's Avatar
yeah, 2.36 and 2.5 would be your best bets. Don't go over 2.5 inches. You will notice considerable low-end lag with 3" piping.
You got SE-RVED!
Old Aug 11th, 2003, 11:49 PM   #6 (permalink)
Bluesr20
well i think ill go with 2.5, when i do go turbo, i plan on using a electronic dump valve, so exhaust does not really matter for the turbo. Just wanted to know a good n/a setup, thanks
Old Aug 12th, 2003, 12:14 AM   #7 (permalink)
OZMAN
OZMAN's Avatar
2.5 inches naturally aspirated,3.0 inches on turbo applications.3 inches is way 2 big for all motor applications u do need sum back pressure,but on a turbo application your turbo is your backpressure.
OZMAN
OZMAN is offline   Reply With Quote
Old Aug 12th, 2003, 02:28 AM   #8 (permalink)
Nxtasy
Nxtasy's Avatar
Send a message via AIM to Nxtasy
I have driven cars with both 2.5 and 2.25 both sr20s and stock except for I/H I felt that the 2.25 was optimal, it offered the perfect blend of low and top end gains, while the 2.5 lost some on the low end. A lot of this debate is preferance, same as in choosing a cam shaft...
"What the hell did I just get beaten by?" "NX2000 biiitch"
Nxtasy is offline   Reply With Quote
Old Aug 12th, 2003, 11:37 AM   #9 (permalink)
bahearn
bitter old man
bahearn's Avatar
Cough cough Bullshit cough cough
Dyno a 2.5" over a 2.25" and you'll see improvements in torque and horsepower. Dyno a 3" over a 2.5" and you'll see the same thing. Even for N/A apps. Butt dynos need not apply.
Bruce in Houston
Old Aug 12th, 2003, 03:59 PM   #10 (permalink)
fugiot
Farms suck!
fugiot's Avatar
You might have more gain on the top end with 3" but the huge low-end loss isn't worth it. 1/4 mi. times will suffer badly.
You got SE-RVED!
Old Aug 13th, 2003, 01:46 AM   #11 (permalink)
Bluesr20
Ill have to agree with fugiot on that one.
Old Aug 13th, 2003, 11:44 AM   #12 (permalink)
bahearn
bitter old man
bahearn's Avatar
Show me the loss. Ignore conventional wisdom amoment and show me documentation.
Bruce in Houston
Old Aug 13th, 2003, 01:21 PM   #13 (permalink)
Bluesr20
go visit se-r.net and read up on exhaust.
In a smaller pipe diameter the air velocity moves much quicker than in a larger pipe diameter, but smaller also limits the amount of exhaust that can flow through. So you need to find that in between,You want an exhaust that flows quickly,but also has the maximum amount of volume,don't just go out and get a truck exhaust or somethin, you'll experience "turbo lag" in a n/a car, no low end,heck why not go get the largest exhaust that'll fit, or run some side pipes?
Old Aug 13th, 2003, 01:23 PM   #14 (permalink)
Bluesr20
by the way, what size of exaust are you running in your car?
Old Aug 13th, 2003, 03:41 PM   #15 (permalink)
fugiot
Farms suck!
fugiot's Avatar
I think it's similar to the way you can siphon gas. The size of the tube sorta pulls it out, you know? If you tried it with a big fat-ass tube, you'd have to have an elephant siphon your gas for you.
You got SE-RVED!
