Old Jun 16th, 2003, 08:00 PM   #1 (permalink)
PrOxLaMuS©
Post Freak
PrOxLaMuS©'s Avatar
Send a message via AIM to PrOxLaMuS©
Cluster problem.. damn tachometer...
Lucky me.. I am one of the few who has an tachometer on my instrument cluster... since I have a GXE.....
but...today I had to change some of the bulbs, so I had to remove the entire cluster....
I changed 2 bulbs.... the speedometer and tachometer. After that i re-installed my cluster and realized, that for some reason my Fuel Light was always glowing, even though i had a full tank of gas.
Then I started up my car, and I realized that my Tachometer doesn't work anymore! So I tried driving it around the block, and when i turned on my left blinker, my tachometer would jump up and down. Meaning that the higher RPM's i am running the higher the needle will bounce back and forth to indicate that my turn signal is on. But when I don't use my turn signal the tachometer doesn't work.
Also my left blinker does't blink anymore only my right one works, even when I turn on my hazards, only the right arrow lights up.
So I went to junkyard and got another cluster, and I tried plugging it in, and the same thing happened, so something must be wrong with the wiring.
Can anyone help me?
What the FuK is the InTeRnEt
*NEW* 1978 Datsun 280 Z and an 1991 Nissan Sentra GXE: Some stuff.. mostly all audio though http://www.cardomain.com/id/pr0xlamus
Classic Z Cars Gallery (NEW SHOTS)
PrOxLaMuS© is offline   Reply With Quote
Old Jun 17th, 2003, 08:57 AM   #2 (permalink)
PrOxLaMuS©
Post Freak
PrOxLaMuS©'s Avatar
someone? anyone?
Nissan wants $100 to diagnose it, and i can't afford it...
please ?
Old Jun 17th, 2003, 01:47 PM   #3 (permalink)
SergioCR
Nissan Fanatic
SergioCR's Avatar
Send a message via MSN to SergioCR
Re: Cluster problem.. damn tachometer...
but now.. damn.. today I had to change some of the bulbs and I had to remove the entire cluster....
I changed 2 bulbs.... speedometer and tachometer, and when I hooked the cluster back up, for some reason the Gas guage is always lit... and I have a full tank of gas.
Also my left blinker does't blink anymore and when I turn on my hazards only the right blinks. I checked the bulb and it's fine.
but here is my HUGE problem... my tachometer doesn't work!
One minute it worked.. i took out the cluster and plugged it back in.. and nothing, doesn't move at all. Anyone know what I could of done?
That sounds like an electrical problem.... did you put all the connectors back in the right place? or maybe there's a short somewhere.... check the cables for cracking or loose ends...
SergioCR is offline   Reply With Quote
Old Jun 17th, 2003, 08:09 PM   #4 (permalink)
PrOxLaMuS©
Post Freak
PrOxLaMuS©'s Avatar
I bought a new cluster today from a junkyard... and still the same thing.
The Tachometer doesn't work, and the left turn signal doesn't light up on the cluster. But here is what's weird, when i turn on my left turn signal, the tachometer jumps up and down.
So instead of a light lighting up, the tach needle moves up an down about 1 inch or so.
2 clusters .. something must be wrong with the wiring
Old Jun 17th, 2003, 08:31 PM   #5 (permalink)
SergioCR
Nissan Fanatic
SergioCR's Avatar
Yep... something's wrong with the wiring... the funny thing is it was working before... did you double-checked everything again to make sure all is plugged where it suppose to be?
Old Jun 26th, 2003, 10:27 PM   #6 (permalink)
PrOxLaMuS©
Post Freak
PrOxLaMuS©'s Avatar
I doubled checked everything and still nothing.
Does anyone have a slight clue about what happened or what I can do? I even lightly sanded off the surface of the connecters for a better connection.
Old Jun 27th, 2003, 10:11 AM   #7 (permalink)
SergioCR
Nissan Fanatic
SergioCR's Avatar
I Think toolapcfan is "the one" for that answer... check with the oracle...
Old Jun 27th, 2003, 04:32 PM   #8 (permalink)
2SR20DE
Nissan Addict
2SR20DE's Avatar
Now I realize that this sucks for you but what your describing happening sounds hilarious. Guages doing whatever the hell they please lights going on and off, could you film it?
93' SE-R
I/H/E, Battery Re-Loc, Gen 2 Hypercoils w/ AGX's, autopower rollbar, RCI 5pts, Azenis.
CA Road Racing Dec 3
Willow Springs International Raceway (Big Track)
www.opentrackracing.com
2SR20DE is offline   Reply With Quote
Old Jun 27th, 2003, 11:19 PM   #9 (permalink)
PrOxLaMuS©
Post Freak
PrOxLaMuS©'s Avatar
LoL.. no i can't.... i have a camera, but no where to hook it up
