Old May 4th, 2003, 09:47 PM   #1 (permalink)
the don 1600
lost and found
the don 1600's Avatar
Send a message via AIM to the don 1600
front wheel bearing
does anyone know how to replace the front wheel bearing on my 91 nx. im going to get the whole hub. and do both sides. do i need to get anything pressed? or need any special tools or do anything to the hubs before putting them in. or is it a simple replace this with that.
the don 1600 is offline   Reply With Quote
Old May 5th, 2003, 11:28 AM   #2 (permalink)
ga16det
ga16det's Avatar
if you get the entire hub you dont need to press anything, just remove and replace, if you buy just the bearing(make sure its oem nissan)you need to press the old bearing out and press the new one in.
check out my ride :) http://members.cardomain.com/ga16deturbo
ga16det is offline   Reply With Quote
Old May 5th, 2003, 02:34 PM   #3 (permalink)
the don 1600
lost and found
thanks ga16det. im going to probably be doin it next week. also nice car.
Old May 12th, 2003, 04:04 PM   #4 (permalink)
fsr20det
i went to the junkyard and jus grabbed a hub, saved me alot of $ and time
Speed Kills....Drive A Nissan And Die!!!
fsr20det is offline   Reply With Quote
Old May 12th, 2003, 09:47 PM   #5 (permalink)
sno
**best avatar award**
sno's Avatar
i went to the local yank and grab today and picked up a spindle that had the hub still attached. only cost me $40, but i'm planning on replacing the bearing. are there any websites that have step by step instructions?
sno is offline   Reply With Quote
Old May 21st, 2003, 10:21 AM   #6 (permalink)
SergioCR
Nissan Fanatic
SergioCR's Avatar
Send a message via MSN to SergioCR
Hi, i replaced all bearings on my B13 a few time ago.... the front bearings needs to be pressed into the hub.... and the old ones are hard to get out... what i did was removing both hubs and have a machine shop to do the remove/press work on them, the rest of the work it's just re-tight everything back in place.
SergioCR is offline   Reply With Quote
Old May 21st, 2003, 11:57 AM   #7 (permalink)
sno
sno's Avatar
so the new bearings can be pressed in by hand but the old ones need to be pressed out by a machine shop? is it expensive to have a shop do that?
Old May 21st, 2003, 06:23 PM   #8 (permalink)
91 SR20
Send a message via AIM to 91 SR20 Send a message via Yahoo to 91 SR20
you can do it all your self if ur a wigger and figure out how to press the bearing out your self. i tryed and i said screw it i gotta take it off and get it pressed out then press the new one in and u gotta spend more money. just get a good one from the junk yard for 40 bucks
adam
91 se-r
91 SUNNY - W11 AVENIER - JDM GT-S FRONT BUMPER - GRILL - SIDESKIRTS - FOLDING MIRRORS - KH/M GUAGES - AGX'S / PROKIT - PR MOUNTS - REVOLUTION CATBACK - BREMBO CROSSDRILLED / SLOTTED ROTORS - FRT & REAR STB. BARS - REAR FOLDING SEATS - NISMO RAD CAP / SHIFT KNOB / STEERING WHEEL
91 SR20 is offline   Reply With Quote
Old May 22nd, 2003, 02:26 PM   #9 (permalink)
Irons
Irons's Avatar
Send a message via AIM to Irons Send a message via Yahoo to Irons
My cv joint boot is ripped and most of the grease is out. When I got my broken axle replaced they wanted to replace the whole axle on me. Can you replace just the joint and spindle?
Irons.
96 GXE
93 Black SE. Parting out.
Irons is offline   Reply With Quote
Old May 22nd, 2003, 03:50 PM   #10 (permalink)
Centurion
freakish poster
Centurion's Avatar
They were correct. It's more cost effective to just throw in an axle assembly. I bet a joint would cost more than a warranted axle, not to mention there'd be more labor invloved.
Centurion is offline   Reply With Quote
Old May 22nd, 2003, 08:15 PM   #11 (permalink)
91 SR20
just change the boot if if recently riped but if its been like that for a while id just change the axle for 40 bucks and it easy to do
adam
91 se-r
