Old Jun 28th, 2002, 01:01 AM   #1 (permalink)
RED92SE-R
Posts: n/a
Lightbulb Tiny (?) electrical problem - 92 SE-R
Ok, I have a nearly perfect 92 SE-R...I've had it for 3 years, it's only been worked on at Nissan dealerships, I've never had any problems with it, always maintained it the best possible way.
However, one little problem is driving me insane...nothing major, it's just a hassle. Here's what happens:
1) The fuse that controls the clock, station presets on the radio (not the radio operation itself), interior light and trunk light keeps blowing every time I put it in. This is the fourth fuse from the bottom on the left side (10 Amp). The label says "room lamp".
2) When I start the engine, the radio comes on and resets at 1:00. The radio comes on, but you have to set the stations every time. This happens when the fuse is blown already - so it's understandable.
3) When the engine is off, I can put the fuse in....but when I open the door, it blows. Basically, that points to the indoor light, triggered by an opened door..and here's why...
4) When the engine is running, even with the blown fuse, if I pull the light bulb out from the ceiling, the radio stops working and the clock is gone!
5) With the engine running and a fuse in (with doors closed because that's the only time it will not blow), when I switch the indoor light to "ON" or "OFF", the fuse blows. When it's in the middle, it's fine.
6) I pulled the light assembly out and those wires seem ok.
7) I looked under the dash and found no visible loose wires
I just replaced the radio (needed to be done) and I'm positive I did it right, the problem existed before and after.
Any help would be appreciated...I'm willing to do anything short of removing the entire dash.
Thanks in advance!
Old Jun 28th, 2002, 02:33 PM   #2 (permalink)
SE-R Kid
Send a message via AIM to SE-R Kid
If the fuse blows when the door is opened, leave the courtesey light TURNED OFF, and see if it still blows...
If it still does, look for a wire that's frayed IN the door jam area, where the wires for the door locks, and windows go... there might me a frayed wire there...
Hope this helps.
91 Civic Si - B16a Turbo
91 Sentra SE-R - Just Purchased
SE-R Kid is offline   Reply With Quote
Old Jun 28th, 2002, 04:36 PM   #3 (permalink)
RED92SE-R
Posts: n/a
When the door is CLOSED, the fuse blows when the courtesy light is swiched to ON or OFF. But not in the middle. That's why I don't think it's the door.
Also, all trouble when the door is opened, because it triggers the light, happens with either driver's or passenger's door. So chances are both doors don't have the same problem.
Tricky, I know...but thanks for the idea!
Old Jun 28th, 2002, 04:37 PM   #4 (permalink)
RED92SE-R
Posts: n/a
Oh, and yes...the fuse blows with the door opened and light OFF.
Old Jun 28th, 2002, 04:47 PM   #5 (permalink)
SE-R Kid
hmm light switched off, open the door and it pops the fuse, and the light turns off from it...
You've got a pinched wire in the door, man. Start looking at the wires in the boot that goes from the door to the chassis!
Old Jun 28th, 2002, 05:56 PM   #6 (permalink)
RED92SE-R
Posts: n/a
I had two posts after your first reply. Read both of them..you'll see it's not the door.
Old Jul 1st, 2002, 09:47 AM   #7 (permalink)
nismo_ser1
Posts: n/a
I would take a meter, and check your constant hot behind the radio, and your dome light connections. Hold the meter on them, then open and close the door. See if one of the leads is grounding out. This will narrow down the possibilites of the problem.
Old Jul 1st, 2002, 10:55 AM   #8 (permalink)
coachflip
Send a message via AIM to coachflip Send a message via Yahoo to coachflip
Definitely check the wires behind the radio, I had the same thing happen to mine in my pathfinder and the sentra, and it turned out to be a bad wire behind the radio, the constant feed to the radio (which holds the time and presets) was shorting on the metal bracket back there. This was repaired in 20 seconds with a nice wire splice and nothing has occured since.
Brent Meints
1991 B13 SE-R
Hyperco Gen 2 on AGX
ACT clutch/es mount inserts
B&M short shifter
AD22VF upgrade w/stainless lines
Everything else is gone - Bring on the Boost!!!!
coachflip is offline   Reply With Quote
Old Jul 1st, 2002, 12:31 PM   #9 (permalink)
RED92SE-R
Posts: n/a
Thanks guys, I'll definitely try it! I appreciate the response.
Old Jul 1st, 2002, 12:31 PM   #10 (permalink)
RED92SE-R
Posts: n/a
Old May 17th, 2004, 12:38 PM   #11 (permalink)
bassmonster
biggest cause of that . make sure that you havent connected the radio constant power to the illumination lead . most people when installing the radio get the meter out and test the leads but fail to remember that illumintion lead will read 12+ as well . so what happens is the illumintion lead gets overloaded and snaps the fuse. your presets go bye bye and it doesnt work anymore.
bassmonster is offline   Reply With Quote
weird electrical problem??? IXLR8se-r B14 95-99 chassis 9 Jun 1st, 2005 08:28 AM
A/C electrical problem tsi200sx B13 91-94 chassis 8 May 1st, 2003 02:16 AM
Request for help: diagnose electrical problem boost Truck & SUV 7 Apr 29th, 2003 01:56 PM
electrical communication problem mayers U13 1993-1997 Altima 2 Apr 4th, 2003 08:17 PM
another electrical problem Laly B13 91-94 chassis 9 Jul 10th, 2002 02:27 PM
