So what year is your car? A '91 or a '93? And what do you mean by "chop car"? The front clip is a different year than the rest of the car? It doesn't really matter what engine you put in, it's the tranny and the cluster you have. If your speedo worked before the swap I can't see what would have changed, as long as you put the same transmission back in. Regardless, if you have an electronic speedo then your transmission needs an electronic speed sensor in it. If it doesn't you can swap out the mechanical sensor for an electrnic one. If your cluster is cable driven then you'd need to swap out the electronic sensor in the tranny for a mechanical one.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
