Electrical Problem - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Nov 3rd, 2012, 11:21 AM   #1 (permalink)
Electrical Problem
I have a 94 Sentra with 154K miles on it and although most everything works fine I have been plagued with electrical issues. Awhile back I lost my panel lights and traced it back to the dimmer switch, I got one from the junk yard that worked about 50% but the most I would have to do is jiggle it and the lights would come on.
Recently I lost the panel lights again and this time decided to just bypass the switch by shorting the two pins together but this time that didn’t work like it did when I tested it before installing the new dimmer switch. Also there was something new this time; I have also lost the buzzer/dinger that tells you your lights are on and my tail lights as a police officer was so kind to point out. I have checked all the fuses even the ones that wouldn’t make sense for this problem and found nothing. Could this be the blinker arm assembly where the light switch is on, if not what should I look for?
Thank you!
Andy1972 is offline   Reply With Quote
Old Nov 3rd, 2012, 07:48 PM   #2 (permalink)
Sup Mod keeping the peace
rogoman's Avatar
Check the ground connections. There's one behind the driver's side kick panel and one on the passenger's side.
KA-T for life, yo!
Old Nov 3rd, 2012, 07:56 PM   #3 (permalink)
Thank you!
I will do that but wouldn't that affect other things in the vehicle. The dome light, head lights, cigarette lighter and radio all work perfectly it's only those three things that don't work correctly. In fact if I'm not mistaken even if I leave the key in the ignition it beeps at me (will have to test that one) it only seems to be associated with thing that come on when the headlights are engaged.
Old Nov 10th, 2012, 01:17 PM   #4 (permalink)
Wiring Diagrams, Relay? Please Help!
I have gone through every wiring diagram that I can find and the only single point that would affect all of these things seem to be the headlight switch arm assembly. I have one on order but if that doesn't work is there anything else anyone can think of? I don't see any common relays but that could be it too. I checked and the buzzer does come on when I leave the key in the ignition so the buzzer works it just isn't activated when I turn the lights on much like the tail lights and panel lights. Are there any more in depth diagrams? I'm using a standard Haynes manual now.
Old Nov 10th, 2012, 04:14 PM   #5 (permalink)
rogoman's Avatar
It's best that you get an FSM for your car; It has very good electrical diagrams. Get one from this web site:
Nissan and Infiniti Service Manuals
KA-T for life, yo!
Old Nov 11th, 2012, 09:30 AM   #6 (permalink)
andy it is the light and turn signal switch mine did the same the thing. I replaced it and mine went back to working properly
jeffo21 is offline   Reply With Quote
Old Nov 13th, 2012, 07:01 PM   #7 (permalink)
PROBLEM SOLVED!
The part was a special order but I did replace the headlight turn signal switch today and that was it! In fact it even fixed a long standing problem I had with only one high beam working. That didn't matter much to me because I don't drive on back roads at night much but that went out in 2005 I think but now it's working again along with the buzzer, tail lights and panel lights! The part was only about: $50 and really easy to replace.
Thank you!!
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
