You should go for the NX2000, the SE-R brakes are not that much bigger than XE. THe NX rotors are wider and larger, calipers are larger and piston is bigger for clamping pressure. There are issues with the rear drum. I would replace the drums woth the discs and get an Altima master cylinder to run the NX 2000 front and rear disc. Get metal master all around pads. Thats my suggestion. Also get goodridge lines and motul fluid
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
I think what he meant by issues, that when you swap out the rear drums for the AD7HA rear discs found on SE-R's/NX/Any B13 with ABS, you have to change out the e brake cables so they'll connect to the discs and you have to swap out the rear spindles and trailing arms. Base model Sentras have the CL18VD front discs, the SE-R front discs are the AD18VE's and the NX fronts are the AD22VF's. You'll want to swap out the Master Cylinder like Crhis mentioned. Your car has the 13/16" bore MC and considering the Altima is a upgrade over the 7/8" one found in the NX an SE-R, I'd spring for the Altima MC. I second the SS lines and the RBF fluid. But for pads, I'd get OEM Nissan pads.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
I have a sentra XE, and I was wondering if the brakes upgrade is dificult to do, and what do I need to get from the nx2000, so I could go look it up in the junk yard ??? help...
I did the SE-R front upgrade as well as the SE-R rear upgrade. I am still using my stock MC w/ no problems. The SE-R front brakes are only slightly bigger, but if you can get the parts for cheap (OR nothing like I did), it is a worthwile upgade.
__________________ 1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
