Crank shaft seal leak. replace oil pan gasket too!?
I have a leaky crank shaft seal and I think the people at autozone may be confused as to what I need. They tell me it is actually the case the timing chain is in and I need to do those two seals(I imagine its one at the engine and one at the outside of the timing chain), they timing case gasket, AND I need to do the Valve cover gasket and theoil pan gasket. They are confusing the seal I need to do right?
Should I try another place and ask for the "crank shaft seal"?
How large is that Main pulley nut?(I have an impact wrench to take it off, but don't know if I have the right socket)
Will I see my bad seal once I have the pulley off?
Sorry for the questions, but I am doing this for a friend tonight and don't have access to his haines manual right now. Ill look at that oil sensor too when I am in there, but this thing is puking oil at start up and shut down, which tells me it is the main seal.
