Old May 23rd, 2008, 11:14 PM   #31 (permalink)
triplefour
thank you im going to work on it later...but what are `clearances` ?
triplefour is offline   Reply With Quote
Old May 24th, 2008, 11:30 PM   #32 (permalink)
IanH
Post Freak
IanH's Avatar
Clearance means the distance between mechanical parts.
I.e. in this gearbox the between rotating parts in thousands of an inch.
A real gap is positive and a clearance, a pre-load is negative and clamps the parts together. I note that they just give a pre-load with no negative in the tables.
I don’t know which transmission is yours so I just read the first one.
Ok in Vol 2, MT -14 shows the main shaft, part numbers 30 and 31 provide the clearance adjustment or preload.
MT-22 shows checking the gear clearances on the main shaft. Useless you feel you must do this, I would leave this, and it will be close, till the second gearbox when you have the car running. It also shows a press to remove the main shaft bearings.
I think you can check the synro wear clearance with the shaft assembled, they do it when the main shaft is dismantled, if in spec and you have no complaints, leave them. MT-24
MT-26 and MT-27 press on main bearings.
MT-31 press in outer race front mainshaft bearing
Adjust mainshaft main bearing pre-load MT-33 shim table MT-102 p161
Note the main bearing cover enables you to change the adjustment shim from outside.
The next type of transmission has a shim on the shaft between the bearing and the shaft land. MT-55
About all the pressing and pulling. I have used three leg pullers on things like this, if you can get a bearing puller holder like as shown in the manual and use a puller on that it would be better.
To re-assemble you can use a hammer, use blocks and things like sockets to position and drive things in and on.
Be careful not to chip anything, I chipped a Jaguar mainshaft once.
If in doubt it would be better to take in to a machine shop or auto shop and have them do the pressing and pulling. Here in Dallas things like this were about $6-10 a piece. No idea on prices these days.
Take everything at one time, saves set up time. ie get your new bearings first.
(Replace the oil seals.)
(get part number of bearing and go to a bearing supply house. On ball race types the last letter often means clearance, you can use tighter clearance bearings. Automotive often uses "c" clearance bearings loose fit ball bearings.)
Good Luck......
1997 Sentra GXE w/195/50 15's and AD22VF, Tach, Halo's, Front seal, Rear SER Disc Brakes Soon to be sold
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old Jun 21st, 2008, 02:11 PM   #33 (permalink)
triplefour
well the cars still sitting in my garage...i figured out the part i need to replace in the transmission is called the `mainshaft front bearing`
nissan part number 32219-62y00 and they want like 100 + shipping for it...
so i called around some other bearing places
found a place called transmission technology
the guy there quoted me 37 for the part 27 for the shipping, so much better...
65 bucks i think i can manage...
i just hope when i put it all back together it works!
Old Jun 21st, 2008, 05:22 PM   #34 (permalink)
IanH
Post Freak
IanH's Avatar
can you get the bearing manufacturer and number of the race ?
If so try the bearing wholesalers, like SKF
