» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Old Oct 14th, 2007, 03:37 PM   #1 (permalink)
Battery Cable Connection
I am finishing up a transmission replacement for a '93 Sentra XE with a GA16DE. After I got into it I found that I also needed to replace the lower control arms, tie rod ends, axles, and clutch. Now that I have just about got the thing back together I have forgotten where the negative/ground cable from the battery connects. Was it to a bolt on the transmission or elsewhere?
I also needed to replace the positive battery cable because the terminal end fell apart when I took it off. The dealer wanted ~$62 dollars for it and I couldn't find one at an independent parts store. However, they make a positive cable end for Infinity's that replaces the old Sentra end perfectly, complete with connectors for the 2 fusible link wires for $9.28. The part number is (24340-51E67 Connector Assy). It crimps on to the end where the old one was.
Thanks for any help on where the negative battery cable connects.
T.W. Trout
twtrout is offline   Reply With Quote
Old Oct 14th, 2007, 04:51 PM   #2 (permalink)
k2000's Avatar
Hi, I know where your suspicious cable goes. It's very simply, it goes on one bolt of the transmission. One big bolt that hang up to the engine. Should not take much than 5 min to fix it !
Ouin, c'est étonnant comment qui torche mon p'tit char ! Bel achat, mon Sentra !
Sentra E 92 4d (first car) Holy one !! dead :'(
Sentra E (turned into XE...or SE) 95 2d (B13) MEAN MACHINE ;)
k2000 is offline   Reply With Quote
Old Oct 14th, 2007, 07:49 PM   #3 (permalink)
Re: Battery Cable Connection
K2000,
Thanks! I suspected that from just looking at the length of the cable and the size of the hole in the connector; however, I didn't remember for sure. Thanks again for your help!
T.W. Trout
battery cable nissanowner1 Pathfinder 8 Feb 14th, 2006 03:53 AM
1991 Pathfinder Positive Battery Cable Junction/Dead Battery Problem chetako Pathfinder 0 Feb 14th, 2006 01:20 AM
95 Pathfinder negative battery cable doktorfaustus77 Pathfinder 5 Jan 16th, 2006 10:03 AM
wow... they really aren't playing... seximagtr Dallas Nissan Enthusiasts 7 May 26th, 2005 03:33 PM
negative battery cable jclemen SR-Series Engines (DE/VE) 6 Aug 4th, 2002 02:49 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
