Old Jun 16th, 2002, 06:05 PM   #1 (permalink)
RED92SE-R
Posts: n/a
Question Rear speaker access/rear panel removal
I'm having a problem removing the rear panel on my 92 SE-R. I removed the three large plastic screws on top of the panel, and I'm trying to figure out what else I need to do to remove it. I'm assuming it's something in the trunk. I'd like to replace the rear speakers.
I'd appreciate any help I could get. Thanks!
Old Jun 16th, 2002, 07:25 PM   #2 (permalink)
RED92SE-R
Posts: n/a
NEVER MIND
I figured it out....
Old Jun 17th, 2002, 05:40 PM   #3 (permalink)
trasen92SER
Rear Speakers
Just a quick question. What did you need to do to remove the panel. i'm thinking of replacing speakers soon also.
Thanks
A redline a day keeps the sludge away
trasen92SER is offline   Reply With Quote
Old Jun 17th, 2002, 08:16 PM   #4 (permalink)
RED92SE-R
Posts: n/a
Rear panel removal
It's actually quite easy.
1) Remove the top screws from the top of the panel inside the car(wide plastic screws). There are three of them.
2) Open the trunk and push the white pins up. The easiest way to do this is using a pair of pliers, where you'd press on the pins to make them thinner, then push up. When you hear a "click", the thickest part of the pin has gone through, and that's all you need.
3) Go back inside and just pull the panel out. Don't force it, otherwise the pins may detach from the panel (it happened to me).
I just bought some speakers, and the holes don't fit very well. If you want a perfect fit, you'll have to drill.
Good luck
Old Feb 14th, 2003, 10:29 PM   #5 (permalink)
motentra
Send a message via AIM to motentra
i had a time trying to get the firickin thing off too..it sucked but i finally got it
If anyone has some clear sidemarkers for a B13 for sale...let me know please!
motentra is offline   Reply With Quote
200sx rear speaker cover chucky200 Audio 3 Jan 7th, 2008 11:43 PM
2001 Sentra - How to remove rear deck panel mwjohnson Audio 2 May 3rd, 2007 04:57 PM
How to pop off rear speaker grills stevem5000 Audio 2 Oct 19th, 2003 02:40 PM
Question: 1998 rear speaker wires zakezuke Audio 7 Jul 16th, 2003 09:46 AM
rear speaker removal mk_sentra Audio 7 Sep 20th, 2002 09:22 PM
