Old Feb 21st, 2007, 06:00 PM   #1 (permalink)
robzero
Question Air blowing when the oil cap is taken off?
When I take the oil cap off of my engine, I notice a bit of air blowing out. Is anything wrong with this?
I've been told by some guy that it's a sure sign the engine to going to blow soon, but I'm having an extremely hard time believing that. Keep in mind this guy was looking at my car with intent to buy, so I'm thinking he's trying to bs a low price out of me.
robzero is offline   Reply With Quote
Old Feb 21st, 2007, 08:30 PM   #2 (permalink)
mrgoose
This doesn't seem strange to me. The crankcase ought to have positive pressure, which is partially alleviated by the PCV system. If you have a clogged/malfunctioning PCV valve, the crankcase pressure could be too high and you should replace your PCV valve (like a $5 part, easy to replace). However, even with the PCV system operating normally I would still expect a modest positive pressure in the crankcase, which would cause the bit of air coming out with the oil cap removed. If you haven't replaced your PCV valve in a couple of years or more I would do so, but otherwise I don't think I would worry. More typical signs that your engine might be in trouble are things like overheating, abnormal sounds, check engine light on, sudden large drop in performance etc.
By the way, if you don't already know, PCV stands for Positive Crankcase Ventilation. You can read all about it here:
Engine: Crankcase Ventilation
mrgoose is offline   Reply With Quote
Old Feb 24th, 2007, 07:55 AM   #3 (permalink)
HATEnFATE
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
He's trying REAL hard to bs you too. tell him to go hump a tree and that you know what your engine is supposed to be doing.
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Old Jun 14th, 2007, 06:16 PM   #4 (permalink)
R3DN1CK
my car does it too. the car is a dohc. everytime the cam cycles the lifter pots go up and down. it's going to make the air move.
R3DN1CK is offline   Reply With Quote
schematic of how a turbo system works pete? Forced Induction & Nitrous Oxide 31 Jun 5th, 2008 03:10 AM
when to use a synthetic oil leerob58 Truck & SUV 15 May 19th, 2006 12:18 AM
Turbocharger: How does it really work....? asleepz Forced Induction & Nitrous Oxide 102 Jan 10th, 2005 12:25 PM
Oil cap question Destined E/CA-Series & GA16i Engines 9 Aug 10th, 2004 10:01 AM
Rubber oil cap woes Dean GXE E/CA-Series & GA16i Engines 8 Aug 19th, 2003 05:07 PM
