Are you removing the old drum setup? you need to use a mini sledge to bang the drum unit off. I think there are 4 bolts on the back of the drum unit to remove from the spindle. You should be able to remove the whole hub after removing the large pin bolt attached to the rear control arms. might be corroded badly. shoot some PB blaster in the pin area and soak overnight. you may need a torch to heat the area not the pin, just the sourrounding area and then hit it with a hammer.
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
