Auto trans - Idle speed too high - Nissan Forum
post #1 of 2 Old Jan 3rd, 2007, 09:41 PM Thread Starter
WesTnine9's Avatar
Exclamation Auto trans - Idle speed too high
My b13 has an auto trans and it's idle speed seems a bit too high. How would I go about lowering my idle speed? -Thanks
security is a superstition
WesTnine9 is offline
post #2 of 2 Old Jan 4th, 2007, 11:42 AM
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
There is an idle adjustment screw on the intake(not sure where it is on the 1.6 but on the 2.0 it's on the right hand side of the car) adjust this screw accordingly to set your idle speed.
directions
Disconnect the throttle sensor harness connector. Start the engine and warm it up until the water temperature indicator points to the middle of the gauge.
Operate the engine at 2000 rpm for 2 minutes under no load.
Race the engine 2 or 3 times under no load, then check the idle speed. Idle speed should be: USA M/T vehicles only. 650 ±50 rpm. Canadian M/T vehicles only. 750 ±50 rpm. All models with A/T transmissions. 800 ±50 rpm (in "N" position). If not correct, proceed to step 4.
Race the engine 2 or 3 times under no load then idle.
Verify ignition timing is 10°±2°B.T.D.C.
Idle Air Adjusting (I.A.A.) Unit
Turn the idle adjusting screw (located on the idle air adjusting unit) to obtain the correct idle speed. Idle speed should be: All M/T 600 ±50 rpm. All A/T 725 ±50 rpm.
Turn the engine off.
Reconnect the throttle sensor harness.
Race the engine 2 or 3 times under no load then idle. Idle speed should be: USA M/T vehicles only. 650 ±50 rpm. Canadian M/T vehicles only. 750 ±50 rpm. All models with A/T transmissions. 800 ±50 rpm (in "N" position).
If not correct proceed to step 11.
Check the A.A.C. valve and harness, repair or replace as required.
The ECM may be the cause of a problem. This however is rarely the case.
I miss my twins...R.I.P. (91 and 92 SE-R)
J
HATEnFATE is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
QR25DE zellx2004 Frontier 3 Aug 4th, 2009 08:11 PM
High idle rpm after new NGK wires, plugs, dist cap. MickeyKnox General Altima/Stanza discussion 2 Aug 18th, 2006 07:42 AM
93 N/A high idle speed AAC cleaning? thunderball Z32 Chassis 300ZX 4 Jul 19th, 2005 11:54 AM
idle speed rusty A32 1995-1999 Chassis 2 Jul 3rd, 2005 09:29 AM
cannot adjust high idle a-game B11/B12/KN13 82-90 chassis 8 Mar 16th, 2005 07:26 AM
You may post new threads
You may post replies
BB code is On
