Old Jun 30th, 2006, 04:48 PM   #1 (permalink)
mcs
1993 Nissan NX 2000, Clutch problem
Hi all,
I was not using this car on regular basis for last three years. The last time I drove, there was no problem. I wanted to drive today but found out a major problem. The engine starts right away, but I can not switch the gears. When I try to put on first or rear gear, it starts screeching. The clutch cable works fine. Would anyone give me any idea about this situation? And, how much do you think it costs to repair? I do oil changing, breaks etc. The most complicated repair I did was changing the starter. I never tried changing clutch before... Is it easy enough for me to change it myself? Is there any good tips on fixing the clutch? Thanks for all your info...
Ps: The car is stick shift
mcs is offline   Reply With Quote
Old Jun 30th, 2006, 04:51 PM   #2 (permalink)
wissnx01
wissnx01's Avatar
Send a message via AIM to wissnx01 Send a message via MSN to wissnx01 Send a message via Yahoo to wissnx01
What was our first clue?
wissnx01 is offline   Reply With Quote
Old Jun 30th, 2006, 05:31 PM   #3 (permalink)
HATEnFATE
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
wiss... That was uncalled for. Good job looking like an ass.
mcs...
It's possible that you didn't reinstall your clutch cable properly. make sure that your bracket it tightened down like it should be and that your clutch adjustment is in check.
Normally to replace the starter it's easier to remove the cable and bracket out of the way. maybe you just didn't get them back where they were.
Maybe your throwout bearning has just worn out since you don't use the car regularly. It's possible that you've thrown a clutch disc spring.
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Do You Have a Nissan More than 10 years old ? You are challenging Nissan...read Pablo14 General Discussion 34 Oct 18th, 2007 12:53 AM
2004 & 2005 Armada brake problem Shannonop Titan & Armada 11 Aug 5th, 2007 02:33 PM
1993 2.4L 2wd nissan pick-up tranny problem C.Whitey General Discussion 0 Dec 9th, 2005 08:38 PM
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 7 Sep 1st, 2005 11:16 PM
SEMA show Spec V's and other Nissan GOODIES cjsmith11878 General Discussion 13 Jan 26th, 2005 09:51 AM
