Old Dec 28th, 2005, 07:34 PM   #1 (permalink)
CaptConan
Odd problem involving radio and dash lights
I've had my 92 Sentra for 3 years now and have put up with never having dash lights. When I installed a radio shortly after purchase, me and my friends looked for burnt out bulbs or damaged wires in the dash. None were found. So the other day I become resolved to solve this problem. After reading this site I've determined that my dimmer switch is F'ed. So, by shorting out the black wire and the red/yellow wire in the dimmer socket, I saw the dash light for the first time ever. However, now my radio doesn't work. When the radio was installed, we could only get it to turn on if at least parking lights were swtiched on. I always thought it was cool to have the radio on without keys... anyways. So I went out and bought a potentiometer thinking that the dash lights and radio were sharing voltage somewhere and if I split it, they would both work. That was not the case, both require all the voltage or nothing. Thinking of a solution, I sought to run wires from the cigarette lighter in parallel with the wires from the dimmer socket so that both might work. Sure enough, the radio and dash lights turned on when I connected them in parallel. But here's the kicker. Now, when I turn on my headlights, the dash lights shut off. I mean, curses dude. Any ideas on what to do?
CaptConan is offline   Reply With Quote
Old Dec 28th, 2005, 07:42 PM   #2 (permalink)
dvdswanson
Post Freak
dvdswanson's Avatar
I'd pull the radio out, get the lights fixed then reinstall the radio but use power from the batter with an inline fuse.
Dave
96 4WD XE Reg. Cab ka24e
Calmini 3" SL, Steering, Lock-rite rear, LSD front
dvdswanson is offline   Reply With Quote
Old Dec 28th, 2005, 08:05 PM   #3 (permalink)
KMG9185
KMG9185's Avatar
Send a message via AIM to KMG9185
i agree no sense of nigger riggin expecially if you want the thing to work right..
kevin
NO REPLACEMENT FOR DISPLACEMENT!!!!!!!!!!
KMG9185 is offline   Reply With Quote
Stock radio power issues..Can anyone figure out the problem? Cuban_B_93_XE Audio 1 Nov 26th, 2005 03:16 PM
Dash, shifter lights out after radio install johnnycar12 B15 2000-2006 2 May 12th, 2005 10:35 PM
No dash lights. Jer_ry B14 95-99 chassis 16 May 11th, 2005 09:25 PM
88 truck- instrument lights quit working when radio installed 90LS400Lexus Truck & SUV 3 Oct 6th, 2004 04:25 PM
dash lights out after radio install hboy35 Audio 4 Aug 17th, 2004 06:23 PM
