» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B13 91-94 chassis
Old Jun 8th, 2002, 10:33 PM   #1 (permalink)
Former B13 owner...
Send a message via AIM to ImportCarTuner
Unhappy I need help with white face gauge install...
Sup everyone... I need help in getting white face gauges installed in my '94 Sentra XE. I've got instructions enclosed with my white faced gauges on taking the dash area apart and needle removal. But I need some info from anyone who's replaced their gauges to aftermarket gauges on getting around to removing the needles. I've heard and read that needle removal is probably the hardest part of this project. A slight wrong move on my part on removing the needles could set me back about $100 or so for replacing my needles. So please, if anyone can give me their insight on this issue, let me know. Thanks.
...:::Wanna see my former Sentra? :(:::...
http://members.sounddomain.com/import_car_tuner
ImportCarTuner is offline   Reply With Quote
Old Jun 9th, 2002, 06:23 PM   #2 (permalink)
hotboy's Avatar
Send a message via AIM to hotboy Send a message via Yahoo to hotboy
yah i did it about 2 months ago. i think the best way to do it is don't remove the needles. instead, carefully remove the the black tops over the needles. these are not actually part of the needles. if you can carefully move black tops across the needles, this will give u more than enough room to put the guages on. hope this helps!!!!!!!!!!!!!!!!!!!
hotboy is offline   Reply With Quote
Old Jun 10th, 2002, 06:13 AM   #3 (permalink)
Define_Sentra
Guest
Posts: n/a
naw dude you still forgot about the huggggggge stick in the speedometer the one you reset when you put new gas? so your gonna need to pull off the needle. i had the same problem just last night!! damm im so mad i think i scrued up the needle of the speedometer. I need help too man. Hey dont try ordering from Import Intelligence dude there instrucions are so complicating and the white faces thats just a sticker to put over your stocks and you'll need needle removement.
Old Jun 10th, 2002, 10:54 AM   #4 (permalink)
hotboy's Avatar
well it depends on your application. if you bought XE guages then I'm assuming u had the holes already punched. I have an se with the tach and I had to get the 200 se guages and cut my clock adjuster needle off. i didn't need a clock up there cause my radio has a clock. well anyway it depends on what model u have. when i had an XE, I did a cluster swap to se so if anybody need help on that get at me!!!!!!!!!!!!
Old Jun 10th, 2002, 03:03 PM   #5 (permalink)
Send a message via AIM to Subculture Send a message via Yahoo to Subculture
Try this link. Hope it helps.
Thomas Fox
93 NX2000
Subculture is offline   Reply With Quote
oil pressure gauge install for ga16? NotAnotherHonda GA16DE 1.6L Engine 20 Aug 21st, 2003 04:16 PM
Guage Face install Cell Cosmetic Mods 0 Jul 9th, 2003 01:39 PM
GA!^DE oil pressure gauge install go4broke44 B14 95-99 chassis 4 Apr 26th, 2003 05:16 PM
gauge install the don 1600 B13 91-94 chassis 0 Jan 21st, 2003 09:02 PM
White face gauge install... ImportCarTuner B13 91-94 chassis 6 Jul 23rd, 2002 01:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
