Old Sep 27th, 2005, 02:49 PM   #1 (permalink)
sdhsisgay
sdhsisgay's Avatar
Send a message via AIM to sdhsisgay
check engine light only on freeway
my 92 sentra 4 speed manual check engine light only comes on when i am on the freeway, and it wil stay on for 15-30 seconds, then turn off for 15 seconds or so, then come on again, over and over again. does anyone else have this problem?
sdhsisgay is offline   Reply With Quote
Old Sep 27th, 2005, 08:20 PM   #2 (permalink)
Ninja
Ninja's Avatar
Send a message via AIM to Ninja
my buddy's sentra did the same thing when his 02 sensor was acting up, might want to sheck that out.
Sentric!
"Hey, is this diff UPSIDE-DOWN?!?" - Three morons trying to swap a J30 VLSD into an S13. What fun that was.
Ninja is offline   Reply With Quote
Old Sep 29th, 2005, 02:09 AM   #3 (permalink)
psalm143
You might try manually checking the error code on your ECU, you can go to this link and it shows you how to do it. http://www.nissanforums.com/showthread.php?t=84062
I also had a similar problem with my 92 sentra. Whenever I accelerated (especially at night), the check engine light would come on periodically. Actually, it was like it would randomly come on while driving, maybe even when I hit the brakes, but once I hit the accelerator, it would turn off. Almost like it switched around, and I could always get it to turn off by usually hitting the brakes and then the gas. I replaced my O2 sensor and I havent seen the light since. I would personally check the code first though...
psalm143 is offline   Reply With Quote
Is cracked exhaust manifold causing Check Engine Light to come on? MrSparkle Truck & SUV 20 Jul 27th, 2008 05:52 PM
How do I check the code for a check engine light? bonestocksentra QG18 1.8L Engine 2 Sep 22nd, 2004 11:42 AM
check service engine soon light waynekog Truck & SUV 3 Sep 7th, 2004 07:00 PM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 21st, 2003 11:15 PM
Check Engine Soon Light? fondoo B14 95-99 chassis 3 May 22nd, 2002 09:33 AM
