Old Dec 7th, 2002, 06:40 PM   #1 (permalink)
Skoorbmax
Posts: n/a
Lightbulb Desperate for help removing a 93's thermostat housing
Hi guys (and gals), I just found these forums as I'm desperate for some help on something - I have a 1993 sentra. The thermostat is locked open so it needs replacing. Today, using a Haynes, I've drained the coolant, and then came the thermostat replacement. Well, I've undone the _three_ screws that hold in the thermostat housing but it WILL NOT come off. I've pulled very hard but it's stuck on there. What am I missing? Haynes says to disconnect the hose going to the housing first, but I see no need to do that. The liquid sealant used originally just seems gummed on really bad and I fear I'll need to bring this to a professional
Old Dec 7th, 2002, 10:18 PM   #2 (permalink)
toolapcfan
Your electrical friend
toolapcfan's Avatar
Smack it with a rubber mallet. Are you able to get any gap at all? If so, try wedging a screwdriver in there lightly trying not to mar the metal, then work on the other side.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Dec 7th, 2002, 10:20 PM   #3 (permalink)
Skoorbmax
Posts: n/a
I can't get any gap at all, and because of the extremely tight confines the best I can get in terms of hitting it is with the end of my hammer (wooden handle). I may try whacking it tomorrow, but since the housing is on a slight slant as you whack it part of that force goes towards actually pushing it harder towards the engine.
I'm hoping to be able to confirm that indeed the only three screws I can see (two at top and one bottom) is all there is, and there is no benefit to removing the hose or anything like that...
Old Dec 7th, 2002, 10:34 PM   #4 (permalink)
toolapcfan
toolapcfan's Avatar
From what I can tell from my '93 Nissan Factory Service Manual regardless what engine you've got, GA16DE or SR20DE, there's only the three bolts you remove. If you need me to ever look something up for you in the book drop me a pm or e-mail. The thing cost me $70 so I'm glad to use it whenever I can.
Rob '93 SE-R
Old Dec 8th, 2002, 01:50 AM   #5 (permalink)
DILLIGAF Racing
Send a message via AIM to DILLIGAF Racing
on my 92, I couldn't get it off either. One thing that helped was with the hose off, so there is just the housing to deal with, stick like a dial rod or something into it, to give you something to pry on. Make sure its not something that will damage anything. But with a little bit of love, some cuts and ALOT of swearing, it will come off
DILLIGAF Racing is offline   Reply With Quote
Old Dec 8th, 2002, 10:14 AM   #6 (permalink)
Skoorbmax
Posts: n/a
Thanks guys i'll give it a go later!
