Old Jun 3rd, 2002, 03:58 PM   #1 (permalink)
Kraus91SE
Posts: n/a
Engine problems Please help.
Car- 89 sentra auto, throttle body injected
At a certin RPM(not sure, no tach, very low though) the fuel cuts then comes back on over and over until you let off the gas. The only thing I can think of it a bad injector or fuel pressure regulator. Has anyone had a simular problem. This is the wife's car and she's been on my back for awhile so I could really use the help.
Old Jun 3rd, 2002, 04:00 PM   #2 (permalink)
RiceBox
Still moderating..sorta
RiceBox's Avatar
Make sure all the vacuum hoses are ok. If one is broken the engine will do wierd things like that.
I had a '93 Sentra Classic (B12)
Mom's got an '03 Altima 2.5S
Dad had a '98 Sentra GXE
Current "rides": 2000 Kona Caldera "Callie", 1996 Specialized Hard Rock "Betty"
RiceBox is offline   Reply With Quote
Old Jun 3rd, 2002, 04:02 PM   #3 (permalink)
Kraus91SE
Posts: n/a
I forgot to mention, I checked all the vacum hoses. Thanks for the respones.
Old Jun 4th, 2002, 03:02 PM   #4 (permalink)
dschrier
Nissan Addict
Can you tell for sure if the fuel is cutting off or does the car just jerk? My car used to do it all the time when I let off of the gas, but now it just does it occasionally mostly while on the highway.
dschrier is offline   Reply With Quote
Old Jun 4th, 2002, 10:22 PM   #5 (permalink)
sentrastud
Garage Sultan
sentrastud's Avatar
Run a bottle (or 2!) or fuel injector cleaner through.
IF any of you havent heard SHELL gasolines had an additive in them that caused sticky stuff to build up inside your fuel system. If you have been using SHELL gasolines for the past year you could have problems.
The easiest remedy is to run fuel system cleaner through ( its $50 Canadian a shot though!) or get your fuel system flushed.
-Nick
JEM (Japanese Export Market) 1989 Sentra DLX
http://community.webshots.com/user/nismonick
http://backfire.ca
sentrastud is offline   Reply With Quote
Clock, antenna, engine and trunk lid problems. Engloid U13 1993-1997 Altima 9 Nov 19th, 2003 03:03 AM
92 g20 engine problems j2qt4u28 General Discussion 0 Jul 24th, 2003 03:52 PM
my 200sx down???????? engine problems down4myne GA16DE 1.6L Engine 3 Mar 30th, 2003 08:45 PM
Few engine problems greensentra B14 95-99 chassis 3 Feb 24th, 2003 07:45 PM
240SX USA version... Engine problems? dugrant153 S13 240SX 1989-1994 15 Nov 5th, 2002 10:26 AM
