No spark - how to test power transistor? - Nissan Forum
post #1 of 14 Old Apr 21st, 2005, 07:20 AM Thread Starter
Question No spark - how to test power transistor?
87 sentra with 2bbl. I have no spark at the coil. I have signal coming from the distrbutor wires (crank angle sensor) to the cpu. I have constant power on 2 of the 4 terminals on the power transistor(one is supposed to, the other is the lead going to the tack which doesn't seem right.), There is signal coming from the cpu to the power transistor when turning the motor over. I have a constant 12v to the coil and i have a signal wire putting voltage to the coil when turning the motor over. I have the service manual on how to test the power transistor and its not testing correctly according to the book. I have went to the salvage yard and tested 5 more transistors and they all tested exactlly the same?? (are they all bad or is the book wrong?) Oh yes all of the fuses tested good. Any ideas? Please help!
mattlok is offline
post #2 of 14 Old May 12th, 2005, 08:47 PM
rimawc's Avatar
Send a message via Yahoo to rimawc
Bad Coil??
I read somewhere that ingition ignitors(power transistor) rarely go bad. Instead, purchase a replacement coil. Connect everything up without mounting it to the firewall, and see if your car will start. If it does, finish installing the coil. If is doesn't, you know that your coil is good, and you can return the replacement coil to the parts store for a refund. It might be helpful if you read my posts. I had a similar problem, and Twiz helped me out.
I wish the best of luck to you,
Will Rima
949-842-3695
rimawc is offline
post #3 of 14 Old May 13th, 2005, 07:49 AM Thread Starter
[QUOTE=rimawc]I read somewhere that ingition ignitors(power transistor) rarely go bad. Instead, purchase a replacement coil. Connect everything up without mounting it to the firewall, and see if your car will start. If it does, finish installing the coil. If is doesn't, you know that your coil is good, and you can return the replacement coil to the parts store for a refund. It might be helpful if you read my posts. I had a similar problem, and Twiz helped me out.
I have tried that already. With no change. It will start for about 10 seconds every now and then, but that is it. The haynes book has a test for it (power transistor) and it test's bad, but i went to a junk yard and test 5 of them and they all tested the exact same. So i don't know if i should believe the book or not.
mattlok is offline
post #4 of 14 Old May 14th, 2005, 10:04 PM
Sentra Specialist
blownb310's Avatar
I have had a couple power transistors fail over the years on customer cars. I always have an extra one around to plug in and test with. However, it sounds like in your case the crank angle sensor is most likey the culprit. Try changing the distributor. I have those around to test with too. They are quite a common failure. They should be easy to find at the boneyard. I can send you one for $25 if you need one. I've moved on to B13's now so I'd be happy to part with all of my B11 ans B12 stuff. Even my last remaining B12 car has a B13 engine in it.
'93 SE-R
'91 SE-R [rallycross]
'89 B12 4WD [GA16DET]
'81 Datsun 210
blownb310 is offline
post #5 of 14 Old May 15th, 2005, 01:05 AM
Nissan Junkie
mille-16i's Avatar
I would agree with blown swap out a distributor and see what happens. I got one for 25 but didn't need it and gave it to my dad for his shop.
Mille's ride
There's no such thing as a soul. It's just something they made up to scare kids, like the boogeyman or Michael Jackson. -Bart Simpson.
mille-16i is offline
post #6 of 14 Old May 16th, 2005, 06:48 AM Thread Starter
Do you have a good used power transistor that you would get rid of also? Just in case?
mattlok is offline
post #7 of 14 Old May 16th, 2005, 07:56 AM
Sentra Specialist
blownb310's Avatar
I sure do. I can ship you one for $15. PM me if you need it.
'93 SE-R
'81 Datsun 210
post #8 of 14 Old May 16th, 2005, 11:44 AM Thread Starter
Is there anyway the ignition condensor could be causing my problems?
mattlok is offline
post #9 of 14 Old May 16th, 2005, 03:47 PM
Sentra Specialist
blownb310's Avatar
No, that's not the problem. My money's on the crank angle sensor.
'93 SE-R
'81 Datsun 210
post #10 of 14 Old May 19th, 2005, 12:15 AM
rimawc's Avatar
Crank Angle Sensro
Just to let you know, and it's in my posts, you don't have to replace the whole distributor. Kragen Auto Parts, and other parts stores, sell the sensor seprately.
Will Rima
949-842-3695
rimawc is offline
post #11 of 14 Old May 19th, 2005, 12:20 AM
Moved on...Ciao!
recycled_toddler's Avatar
Question
Originally Posted by rimawc
...you don't have to replace the whole distributor. Kragen Auto Parts sells the sensor seprately.
Hold the phone...Kragen (aka Schuck's here) sells the guts for the non-vacuum-advance Sentra/Pulsar distributor? Seriously??? How much? I didn't know that was all possible, the books all say that the whole distributor has to be replaced as a unit. If you're right, I'm getting the guts!
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline
post #12 of 14 Old May 19th, 2005, 07:23 AM
Sentra Specialist
blownb310's Avatar
Yes thanks rimawc,
I am aware that you can replace the internals, but I'd rather get a used distributor for $25 because it's quicker, easier, and cheaper. Either way, it's nice to know we have options.
'93 SE-R
'81 Datsun 210
post #13 of 14 Old May 20th, 2005, 11:22 AM Thread Starter
Is it cheaper than $ 25 ???
mattlok is offline
post #14 of 14 Old May 22nd, 2005, 08:45 PM
rimawc's Avatar
The replacement sensor is priced at around $225.
Will Rima
949-842-3695
rimawc is offline
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B11/B12/KN13 82-90 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Ignition power transistor TEST shrkb8 New Member Forum 3 Jul 1st, 2010 02:57 AM
87 Pulsar (E16i) ignition FIXED!! nastynissan E/CA-Series & GA16i Engines 6 Feb 27th, 2009 11:27 PM
anything that comes close vsp3c Nissan GTR/Skyline 27 Jun 5th, 2003 12:30 AM
Dash power transistor RiceBox B11/B12/KN13 82-90 chassis 2 Jun 19th, 2002 10:22 AM
power door locks superfro86 B14 95-99 chassis 0 Jun 15th, 2002 06:05 PM
You may post new threads
You may post replies
BB code is On
