Old Nov 3rd, 2002, 01:36 AM   #1 (permalink)
7RIPP3R
7RIPP3R's Avatar
Unhappy Door Adjustment help
Supp all!
Was wondering if NE of you guys had experience in adjusting the door hinges?... My door gives a nice "KA-THUNK" sound to close it. What hapens is that it hits the latch but i have to pull in and up to close it properly.
Is there a way to do this adjustment with out dismanteling the front fenders? I was looking at it and it seems hard to get at the bolts without removing the front part of the car...
I tried the latch first, the door closed easily but it dont line up with the body when shut...
would appreciate the advise...
7RIPP3R is offline   Reply With Quote
Old Nov 3rd, 2002, 02:06 AM   #2 (permalink)
sentrastud
Garage Sultan
sentrastud's Avatar
im having the same problem kinda. The passenger door wont open from the inside unless you pull the door up a bit. Ive moved the striker piece around a bit but it dont help, any suggestions?
-Nick
JEM (Japanese Export Market) 1989 Sentra DLX
http://community.webshots.com/user/nismonick
http://backfire.ca
sentrastud is offline   Reply With Quote
Old Nov 3rd, 2002, 06:15 AM   #3 (permalink)
Centurion
freakish poster
Centurion's Avatar
You need to replace the door pin bushings...typical Nissan.
1993 Sentra XE auto (original owner)
2005 NISMO Frontier
Centurion is offline   Reply With Quote
Old Nov 3rd, 2002, 10:25 AM   #4 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
Send a message via ICQ to Crazy-Mart Send a message via MSN to Crazy-Mart Send a message via Yahoo to Crazy-Mart
just buy the little bushing it will do the trick... ive replaced several of those and it works well... nissan sell those $$$$$... but its worth it !
the pin rarely need to be changed... unless its grooved..
Crazy !
Sentra Sport Coupe 87 Turbo
14.850@97.454mph
H&R Spring, 15psi, TMIC, 370cc, Nismo mount and pulley, Almasi tuned ecu...
Crazy-Mart is offline   Reply With Quote
Old Nov 3rd, 2002, 10:37 AM   #5 (permalink)
7RIPP3R
7RIPP3R's Avatar
Bushings aye... kewl i'll get on it... hopefully they don't cost $20 bucs a pop.
Old Nov 5th, 2002, 01:31 PM   #6 (permalink)
JonHasAn89SE
Posts: n/a
Had the same problem with mine when I bought it. The pin for the door hinge had worked itself loose. Lifted up on the door and knocked the pin back in with a hammer. All's fine now.
Old Nov 5th, 2002, 01:36 PM   #7 (permalink)
7RIPP3R
7RIPP3R's Avatar
Just got the bushings ($5.15 each) small metal pieces. I got 2 of them and will replace the bottom part of the door hinges. Will let you guys know the outcome.
Jon I'll check both doors and see if the both are in order. Thanks for the insight.
Old Nov 6th, 2002, 07:45 AM   #8 (permalink)
blownb310
Sentra Specialist
blownb310's Avatar
You will need at least one of the hinge pins replaced, the lower one. For a door that is as far out of alignment as you've described, you have gone far beyond wearing out the brass bushings. You now definately have at least one badly grooved pin. BTW, I have found the lower pin to be quite difficult to drive out at times. First, knock out the door check pin, to allow the door to open fully. I have modified a slightly curved air chisel bit, for the job. It works great. I say slightly curved, because you will find that you can't get a staight punch to contact the pin directly. There isn't enough room. Also, make sure you pack the new bushings in wheel bearing grease while putting them in. Lastly, the bushings and pins can be gotten at auto parts stores as well. I found them at my local Napa, on those cards hanging on the "Help" racks. Cheers
'93 SE-R
'89 B12 4WD GA16DET
'86 B11 Euro-Rallycross car
'81 Datsun 210
'77 Datsun B210
blownb310 is offline   Reply With Quote
Old Nov 6th, 2002, 11:20 PM   #9 (permalink)
AVERAGE
Nissan/Mazda Gumshoe
AVERAGE's Avatar
Send a message via MSN to AVERAGE
good, ill definetly have to invest in some of those myself. hopefully, that will fix my problems too.
<a href="http://www.chibangin.com"><img src="http://www.chibangin.com/pics/banner.gif" width="440" height="75" border="0"></a>
AVERAGE is offline   Reply With Quote
Old Nov 7th, 2002, 01:16 PM   #10 (permalink)
7RIPP3R
7RIPP3R's Avatar
Thanks for the tip 310!
I bought just 2 out of the 8 that I might need because it is $5+ a pop. I might be able to fully do the job right if these parts are cheeper at my local car shop.
Old Nov 11th, 2002, 02:28 PM   #11 (permalink)
7RIPP3R
7RIPP3R's Avatar
Talking DONE!
What up y'all!
Thanks again for the tip everybody! worked on this yesterday (took me only 3 Hr's ) but I got it done The door swings to a nice close with no effort. whooo hoo!
peace!
Old Nov 11th, 2002, 10:49 PM   #12 (permalink)
sentrastud
Garage Sultan
sentrastud's Avatar
speaking of doors swinging, anyone know what the best lubricant for the door is? My rear door is kinda difficult to move...
-Nick
http://backfire.ca
Old Nov 12th, 2002, 07:43 PM   #13 (permalink)
7RIPP3R
7RIPP3R's Avatar
Nick-
I did not have access to shop grease so I used a silicone based grease I use on my MTBike.
Old Nov 12th, 2002, 11:04 PM   #14 (permalink)
sentrastud
Garage Sultan
sentrastud's Avatar
and it worked out good?
-Nick
http://backfire.ca
Old Nov 13th, 2002, 10:41 AM   #15 (permalink)
7RIPP3R
7RIPP3R's Avatar
Thumbs up
so far it is working good. I placed a good amount and it's holding up.
