Old May 24th, 2002, 05:10 PM   #1 (permalink)
dschrier
Nissan Addict
Serious problem with my transmisson....
My 90 b12 has problems with its transmisson. The weather here in NH has been far from cold lately and still, my car will not shift. Sometimes it shifts like a dream but others, even at a stoplight with my clutch pressed in for over 10seconds, the car will not go into any gear. Also, 50% of the time I grind my gears trying to get the car into reverse. I got a new clutch at 110,000 and trany oil changed at 125,000 and my car only has 140,000 on it now and I don't find myself to be hard on the clutch at all. Does anyone know what could the problem be? I would hate to drop money on a new clutch or redone gears if thats whats wrong since I'll be getting a new car in a year after I grad. from college. Thanks.
dschrier is offline   Reply With Quote
Old May 24th, 2002, 08:37 PM   #2 (permalink)
dschrier
Nissan Addict
I've been reading a lot online and found that I may need a new clutch cable. I adjusted the clutch a few weeks ago and the problem went away, but now it's back, I could adjust it higher up even, but I've read the higher the clutch is up on the pedle the more likely the clutch is to start slipping and burn out. Is this true?
Old May 26th, 2002, 02:59 PM   #3 (permalink)
RiceBox
Still moderating..sorta
RiceBox's Avatar
You would be able to feel if the clutch was slipping.
I had a '93 Sentra Classic (B12)
Mom's got an '03 Altima 2.5S
Dad had a '98 Sentra GXE
Current "rides": 2000 Kona Caldera "Callie", 1996 Specialized Hard Rock "Betty"
RiceBox is offline   Reply With Quote
Old May 26th, 2002, 09:11 PM   #4 (permalink)
dschrier
Nissan Addict
I adjusted my clutch again, and everything is running smoothly now. The funny thing is that I adjusted it only a few weeks ago and it was shifting fine then got bad again all of a sudden. It might be time for a new cable soon I guess..
Old May 26th, 2002, 09:15 PM   #5 (permalink)
RiceBox
RiceBox's Avatar
The cable is easy to change. Make sure the nut on the opposite side of the adjustment knob is tight or it will keep getting loose
Old May 26th, 2002, 09:18 PM   #6 (permalink)
dschrier
Nissan Addict
Yeah, I made sure of that. It was pretty rusted before so I hope the locknut isn't going anywhere. How much does a new cable run ($)?
Old May 27th, 2002, 08:48 AM   #7 (permalink)
RiceBox
RiceBox's Avatar
I paid $25 canadian
Old Mar 29th, 2006, 06:25 PM   #8 (permalink)
racingnismo
racingnismo's Avatar
Send a message via AIM to racingnismo
did the change of the cable fix the problem???
Racingnismo: B12: E16i: 1988: 4-spd: Manual :D: 2-Dr: Intrax lowering springs (Lowy GO!!!): K&N: 2.25" cat-back piping: "Venturi" type exhaust:
racingnismo is offline   Reply With Quote
Old Mar 29th, 2006, 07:34 PM   #9 (permalink)
mikewiebe1987
ive been having odd clutch cable issues too lately, i adjusted the clutch to tighten it abit, barely, it seemed ok, a day later my car started stalling and sputtering on accelleration, if you hammered the throttle slow then hard and let the clutch out every so carefully half the time it would just run oin that gear but sounds like its on 3 cylinders,revvin out trying to keep up, the other half it would die, idle was fine, shifts were seamless, just throttle application,
it could have been all cylinders and major clutch slippage all iknow is i loosened the cable and now it feels loose obviously but it doesn't stall sputter or anything, im scared to adjust it right now im low im gas hahahaha so ill adjust it later but yeah, very very odd
ps plugs and wires did nothing
mikewiebe1987 is offline   Reply With Quote
Old Mar 30th, 2006, 02:22 PM   #10 (permalink)
bob89sentra
GA16I Guy
bob89sentra's Avatar
Sounds like a stiking clutch cable. When you let the pedal out it probbaly doesn't engage the clutch fully, then slips the rest of the way causing you to stall. If you tighten the clutch up too far it can make the clutch slip, and/ or I have seen it make the cable bind up giving you inconsistant clutch ingagement. You might try replacing or lubing your clutch cable, so you can run the cable at the right tension.
89 Sentra owner 9 years 205,000 miles and counting!
bob89sentra is offline   Reply With Quote
Old Mar 30th, 2006, 03:34 PM   #11 (permalink)
mikewiebe1987
what should i use just like some axle grease or something
Old Mar 30th, 2006, 03:41 PM   #12 (permalink)
bob89sentra
GA16I Guy
I use a Teflon spray lubricant, but I think just about any oil or cable lube would work fine. I don't remember if you can remove the cable from the housing, if you can you could try a graphite or white lithium grease.
Old Mar 30th, 2006, 06:41 PM   #13 (permalink)
mikewiebe1987
hmmmm im at work now, drove my car on lunch break, seemed fine this mornin, first part ofl unch now its runnin shitty but i can still drive without stalling it or slipping it, or as best as i can tell im not....this is probably a bad cable eh? would it be worth it getting a junkyard cable?
you just mean powdered graphite right? i think thats all it is
Old Mar 30th, 2006, 06:48 PM   #14 (permalink)
mikewiebe1987
also, how much play should therre be on the adjustment knob above the tranny, help i have 15 min till im off and i gota try adjusting it with amonkey wrench and vice grips:S:S:S
e16s 87 4dr wagon frwd
Old Apr 3rd, 2006, 10:39 AM   #15 (permalink)
mikewiebe1987
well i replaced the cable, which was a bitch, haynes neglets the 87's because u need to take the whole dash off for proper access , and even i had to pry on some heat ducting to slip the cable on and off, maybe it was just mine, anyways it feels tightn ow but if i drive hard itl start to slip and stall, i think i just need to adjust it properly now, which seems to be my difficulty,
also does the adjustment nut need to be pretty tight because it SEEMS like my cable looses tension if i drive hard on it after adjusting it, but im scared to overtighten it because i bought a napa clutch cable with a rubber adjustment knob that if i tighen too tight may damage the rubber or actually give it more play who knows
ps u also need to pull the steering wheel to properly take out the dash, didnt' have time to figure it out or go get a puller so i trimmed my dash underneath the guage cluster so it slips over but will be covered when i reassemble the dash
Serious parking spot problem El Capitan L30 1998-2001 Altima 14 Mar 28th, 2005 07:12 PM
Engine idle freaked out, went right back to normal sfhellwig GA16DE 1.6L Engine 27 Oct 24th, 2003 01:40 PM
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
serious transmisson problem wcay J30 1989-1994 Chassis 8 Jun 16th, 2003 07:40 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
