Old Nov 11th, 2004, 02:02 AM   #1 (permalink)
winstonsmith
winstonsmith's Avatar
trunk rattle problem
I have two 10" subs in my trunk that have caused the trunk lid braces to break away from the trunk lid. Now it rattles like hell and sounds terrible. Just wondering if anyone else with a first generation Pulsar has had the same problem and what you did to fix it. What were the braces glued to the trunk lid with? Is there something else I can put between the braces and the lid? Some kind of silicone sealant? Maybe some kind of padding like weather stripping or something? I know about stuff like Dynamat but I don't want to spend a bunch of cash. I just need the trunk lid to stop rattling against the braces.
winstonsmith is offline   Reply With Quote
Old Nov 11th, 2004, 08:13 AM   #2 (permalink)
astreamk1
B12 Enthusiast
astreamk1's Avatar
I have run into the same problem with hood bracing. If you just want to stop the vibration, you could probably use silicone or some kind of rubberized weatherstripping. You basically just want something to fit between the 2 parts. you local HomeDepot should offer several inexpensive options to your problem.
My Car Domain Page.
astreamk1 is offline   Reply With Quote
Old Nov 12th, 2004, 05:04 PM   #3 (permalink)
ahardb0dy
Nissan Addict
ahardb0dy's Avatar
after you secure the trunk bracing back in place you should dynamat ( or similiar material) the whole trunk lid, that should eliminate the rattle, I have 2 12's in my sentra trunk and that's what I'm going to do one day,
ahardb0dy is offline   Reply With Quote
Old Nov 12th, 2004, 06:34 PM   #4 (permalink)
Spelchy
Whore Slut Bitch
Spelchy's Avatar
Send a message via AIM to Spelchy
Now I had an N13, but here's what I used for rattle problems:
It's basically bubble wrap, except I think it was 2 layers thick and it has reflective wrap on either side. Anyway, I didn't have subs but I did have a problem with rattles and squeaking, and this stuff worked good. It's really, really cheap too.
I got it at home depot, in the insulation section.
Club Mofo's Paint Curator and Canadian Ambassador to OT
Spelchy is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Trunk power lock no longer functional.......... 94Sentra A32 1995-1999 Chassis 5 Mar 28th, 2004 06:58 AM
problem with alpine amp, need help ahardb0dy Audio 6 Jan 1st, 2004 01:06 PM
My Trunk Setup Old Vs. New! maxedout97maxima Audio 6 May 16th, 2003 10:52 AM
Trunk Rattle Nostrodomas Audio 8 Aug 23rd, 2002 08:18 PM
