» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > B11/B12/KN13 82-90 chassis
Old Oct 19th, 2002, 10:23 AM   #1 (permalink)
dschrier
Nissan Addict
Wheel bearing or hub bearing...
Well I found out that the noise my car has been making is the right wheel bearing. The tire and wheel doesn't move at all if shaken up/down or side to side, but if you jack the car up and just run that one wheel man does it sound bad. Anyways, I went to a local garage and asked for an estimate and they said a 90 sentra doesn't have a wheel bearing but is called a hub bearing instead. Is this correct? I don't know much about suspension and stearing systems but would just like to know the correct terminology so I don't get screwed over by some mechanic.
dschrier is offline   Reply With Quote
Old Oct 19th, 2002, 03:21 PM   #2 (permalink)
nyit240
is it the front or the rear........?
nyit240 is offline   Reply With Quote
Old Oct 19th, 2002, 04:55 PM   #3 (permalink)
dschrier
Nissan Addict
Front right, sorry.
Old Oct 20th, 2002, 12:20 AM   #4 (permalink)
LittlebittaContact
Nissan Fanatic
LittlebittaContact's Avatar
Send a message via ICQ to LittlebittaContact Send a message via AIM to LittlebittaContact Send a message via Yahoo to LittlebittaContact
yea, the front (as a matter of fact, all front wheel drive vehicles) have a hub assembly instead of the inner and outer wheel bearings that are found on rear wheel drive vehicles.
they usually are more expensive, the front one for my car is about 55 bucks...just so you know.
hope this helps
Scars Heal, Glory Fades
All we're left with are the memorys we made.
LittlebittaContact is offline   Reply With Quote
Old Oct 20th, 2002, 11:29 AM   #5 (permalink)
dschrier
Nissan Addict
Would the bad hub bearing cause a bit of a pull to the right if the right one is bad? I am trying to decide if I need an alignment as well as a new bearing.
Old Oct 20th, 2002, 10:34 PM   #6 (permalink)
RiceBox
Still moderating..sorta
RiceBox's Avatar
Fix the bearing first. If the car still pulls then get the allignment. You can also look at your tires. If they have any wierd wear patterns then get an allignment.
I had a '93 Sentra Classic (B12)
Mom's got an '03 Altima 2.5S
Dad had a '98 Sentra GXE
Current "rides": 2000 Kona Caldera "Callie", 1996 Specialized Hard Rock "Betty"
RiceBox is offline   Reply With Quote
