Ticking sound from engine - Nissan Forum
post #1 of 17 Old Apr 17th, 2004, 01:17 AM Thread Starter
Lately when i start the engine or rev it a little hard on stop and go or high way I can hear some ticking sound from the engine. It's NOT those deisel engine ticking sound. It sounded like pistons/valves/metal chain rubbing on the engine block. Any idea? The car has 122000miles now. hope this is not a bad sign
Can't get my Sig to work
nyit240 is offline
post #2 of 17 Old Apr 17th, 2004, 12:42 PM
Post Freak
minute rice sentra's Avatar
Does it sound like maybe valves? It could be as simple as adjusting your valve clearance, have you checked the oil yet?
EDIT: I forgot the GA's had hydraulic lifters so they can't really be adjusted to my knowledge, here's a little something from the service manual, if there's more than a 1mm or .04" gap between the rocker arm and the lifter with the valve closed, air could be trapped in the lifter and needs to be bled out by running the engine at 1,000 rpm under no load for about 10 minutes, but if the lifters are still noisy they need to be replaced.
Originally Posted by red_devil
may the boost be with you.
minute rice sentra is offline
post #3 of 17 Old Apr 17th, 2004, 01:32 PM
Garage Sultan
sentrastud's Avatar
It might be the timing chain tensioner, usually when this goes, your engine sounds like a diesel at idle. If its not completly broken thoguh it may produced the sound your hearing. It will sound sort of like a repeating scraping noise.
It could also be a little bit of valve slap or valve lash. Getting your valves adjusted would clear that.
-Nick
JEM (Japanese Export Market) 1989 Sentra DLX
sentrastud is offline
post #4 of 17 Old Apr 17th, 2004, 05:24 PM
Post Freak
Gsolo's Avatar
Send a message via MSN to Gsolo Send a message via Yahoo to Gsolo
worst case could be bearings
Student at UTI Avondale
2nd place SkillsUSA/VICA WA State Automotive Maintenence '04
1970 Chevy BelAir 350V8 300hp...soon to get M21
Gsolo is offline
post #5 of 17 Old Apr 17th, 2004, 06:24 PM
To continue the thread with similar symptoms, my GA16i just started making this noise today, but only when engine is under load (sounds like it would be valve tapping).
Is this air trapped in the system that idling at 1000rpm or so for 10 min would take care of?
If not, how would one go about replacing the lifters, or is this a mechanics job?
Thanks!
Todd
1992 240sx. Stock for now..
Elbow Greese is offline
post #6 of 17 Old Apr 17th, 2004, 08:56 PM
My 87 pulsar(e16i)..made a kind of tapping ticking noise when I bought it..sounded like the rocker arms were tapping the valve cover...got real bad about 5 thousand miles later, opened the valve cover and my rocker arm shaft was busted right in half(the bolts holding the shaft to the cylinder head worked there way out over time and ended up busting the shaft)...well I got a used shaft for 10 bucks and slapped it on, I also adjusted the valve lash(think thats what ya call it)with a feeler gauge(really don't know if I did it right)...Put everything back together and the sucker still made a light tapping noise...I said screw it and 20,000 miles later its still making that same noise, no better and no worse...
Dave
Bugalou is offline
post #7 of 17 Old Apr 18th, 2004, 06:48 AM
Dumbass
50dollasentra's Avatar
Send a message via AIM to 50dollasentra Send a message via Yahoo to 50dollasentra
My 89 Sentra has a new head and all and it still taps. Then i found that the Timing Chain Wore a hole in the cover. That set me back $100. But since that got fixed it still taps. Im startin to think that the cam might be too tight and makes that ticking noise. You might want to check that out because my car started tappin at about the same mileage.
50dollasentra is offline
post #8 of 17 Old Apr 18th, 2004, 10:32 PM
Garage Sultan
sentrastud's Avatar
Did you just replace the cover, or did you have the black plastic chain tensioner replaced too??? Thats the chain wears a hole in the cover, becuase the tensioner is broken.
-Nick
post #9 of 17 Old Apr 18th, 2004, 11:29 PM
Soon to be GA16it
Mervic's Avatar
Just a guess, maybe your engine is detonating. Detonation sounds like marbles in paint spray can. DOes it make the noise under no load? Is it worse uphill? Try higher octane gas and check your ignition timing.
Mervic is offline
post #10 of 17 Old Apr 19th, 2004, 01:15 PM
Post Freak
Gsolo's Avatar
thats what i was wondering, like a slight pinging or something, like if timing was barely to far or a lot of carbon build up
Gsolo is offline
post #11 of 17 Old Apr 20th, 2004, 11:26 PM
Well, unfortunatly it's worse than that.
My T-chain broke! - or at least that's what the mechanic told me.
I'll be able to dig in and check it out more later in the week.
Is this engine an interference design? (Will the pistons hit and bend the valves when the chain goes?)
Seems kinda wierd for it to snap so quickly after just starting to hear the rattle noise (1 day!).
Anyone know of a good writeup on how to change the chain on one of these beasts?
I've done it before on my truck, so I know the general process, it's just the transverse mounted engine that's got me scratching my head a bit.
Thanks for the input!
Todd
post #12 of 17 Old Apr 21st, 2004, 01:16 AM
Post Freak
Gsolo's Avatar
Todd
yes its interference. and to change it on transverse engine you pound it with a 9iron a few times
Gsolo is offline
post #13 of 17 Old Apr 21st, 2004, 02:31 PM
Moved on...Ciao!
recycled_toddler's Avatar
Exclamation
Originally Posted by minute rice sentra
EDIT: I forgot the GA's had hydraulic lifters so they can't really be adjusted to my knowledge...
The '89 B12 I had with the 12-valve engine had a crate GA15i in it (Believe it or not, they exist) and the valves had screw adjusters, not hydraulics like the GA16i...identical-looking valve train otherwise. I was surprised, so after finding no one had data on how to set the lash, I set all valves at .011 hot.
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline
post #14 of 17 Old Apr 21st, 2004, 05:50 PM
I know some engines have some kind of protection in case a timing belt goes, does a Ca18de have it??
Dave
Bugalou is offline
post #15 of 17 Old Apr 21st, 2004, 05:55 PM
Garage Sultan
sentrastud's Avatar
Todd
It does seem kinda wierd for it to break so quickly? Are you sure he didnt say chain guide, or tensioner???
The best write up that I know of is the Haynes Repair Manual for the Sentras of our vintage. You can pick one up for 10 bucks at Pep Boys or Canadian Tire.
-Nick
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > B11/B12/KN13 82-90 chassis
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Do You Have a Nissan More than 10 years old ? You are challenging Nissan...read Pablo14 General Discussion 34 Oct 18th, 2007 12:53 AM
Free GA16 engine Engloid GA16DE 1.6L Engine 12 Apr 25th, 2004 08:33 PM
manuel with spec v no1d B15 2000-2006 49 Mar 8th, 2004 04:44 PM
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 10:09 AM
Hissing sound heard in the engine sh348 GA16DE 1.6L Engine 1 Apr 30th, 2003 05:53 PM
You may post new threads
You may post replies
BB code is On
