Old Apr 15th, 2004, 01:20 AM   #1 (permalink)
shitaké
alternator problem?
'90 sentra
I was driving along and this indicator light came on. it was on the left of the steering wheel, i think it's the headlight symbol, but it was red. I didn't know what it was for. then my e-brake light came on. this same problem happened to me on my other car, and my alternator belt was loose (mounting bolt broke off). so I check the belt on the sentra, and it's fine. maybe the battery is not holding the charge? now I don't know, is it the alternator or battery? just asking to be safe, I don't wanna spend on both, unless I need to.
shitaké is offline   Reply With Quote
Old Apr 15th, 2004, 07:13 AM   #2 (permalink)
50dollasentra
Dumbass
50dollasentra's Avatar
Send a message via AIM to 50dollasentra Send a message via Yahoo to 50dollasentra
Originally Posted by shitaké
'90 sentra
Go to Advance auto to get them to test yur ish. But i dont know about the brake light thing. My brake light stays on all the time for no reason
50dollasentra is offline   Reply With Quote
Old Apr 15th, 2004, 08:36 PM   #3 (permalink)
Bugalou
I have one of those cheap $10 volt meters that I use...I check the battery with the car off(should read about 12 or 13 volts)..I then start the car and it should read about 14 or 15 volts then I know my alternator is good..The battery you really can't tell if its good or bad unless you have a load tester(bring it in to Carquest or one of those free battery alternator checker auto stores)
Bugalou is offline   Reply With Quote
Old Apr 15th, 2004, 10:59 PM   #4 (permalink)
1989SentraOK
Tha Sleepin' B12
1989SentraOK's Avatar
Send a message via AIM to 1989SentraOK Send a message via MSN to 1989SentraOK Send a message via Yahoo to 1989SentraOK
My Sentra's been a bit messed up lately, the battery acts like it won't hold a charge but you hook it up to a voltmeter and it's good...turns out the little red alternator wire is not attached to the battery....if that helps any...might check that out...
My CarDomain Page
You can build a fast Honda. You can build a faster Nissan.
1989SentraOK is offline   Reply With Quote
Old Apr 16th, 2004, 12:51 AM   #5 (permalink)
Red_Coupe
NISSAN SLAP NUTS
Red_Coupe's Avatar
This is a way to say check your car out there is something wrong .
your alt. is prob.not giving your battary a charge,and the car is running off the battary.
check your alt. and yor battary too. most likley it will be the alt. is bad.
Sabendo muito sobre nada
B12 COUPE W/SR20DE R.I.P
B13 SE-R R.I.P. just to hard on cars.
Red_Coupe is offline   Reply With Quote
