Old Sep 11th, 2002, 06:06 PM   #1 (permalink)
dschrier
Nissan Addict
What does a bad pcv valve cause?
What problems would a clogged pcv valve cause? I tried changing mine cause it's caused with gunk along with the hose but I can't get the thing off myself so I need to go get it done at a garage. Would a clogged valve cause pinging possibly? I seem to ping even on hot days with 93 octane fuel. I have an all stock 90 b12 with 148,000 miles.
dschrier is offline   Reply With Quote
Old Sep 12th, 2002, 09:35 AM   #2 (permalink)
JonHasAn89SE
Posts: n/a
I'm no expert, but I found this web site recently: http://autorepair.about.com/library/ts/bl303a.htm. It describes common engine performance symptoms and their causes. The problem you're describing sounds like:
There is a rattling noise from the engine when you accelerate:
Your car runs well all the time. But when you press on the gas pedal to accelerate or to go up a
hill, the engine rattles like the cylinders are full of marbles.
Possible causes:
1.The ignition timing may be set wrong: Adjust ignition timing.
2.The engine may be running too hot: Check and repair cooling system.
3.There may be a vacuum leak: Check and replace vacuum lines as required.
4.Incorrect grade of fuel: Fill with the correct, or higher, octane fuel.
5.There is an excessive amount of carbon built up in your engine: Clean carbon from
valves and combustion chamber. (Not a DIY job)
6.There may be a fault in the computerized engine control system: Check engine control
systems with a scan tool. Test circuits and repair or replace components as required.
(Generally not a DIY job)
This site explains some possible symptoms of PCV valve failure as:
* Engine uses more oil than normal, and there is (or is not) some smoke from the exhaust. <OR>
* Engine is using more oil than normal. Oil puddles under the car when parked:
It didn't give any other symptoms related to PCV valve failure. I'm sure there are some though.
Anyone else, feel free to dispute or confim this.
Jon
Old Sep 12th, 2002, 11:55 AM   #3 (permalink)
bahearn
bitter old man
bahearn's Avatar
The PCV valve is a simple ball check valve. It is oriented so that vapor flows from the cam/valve cover to the vacuum source, usually the intake manifold or tract. It has two failure modes:
  • Stuck open
  • Stuck closed
Stuck open would allow normal flow of crankcase oil vapor to the vacuum source, but would allow intake pressure pulses to flow back into the cam/valve cover. This could allow gasoline into the engine cases. Gasoline has almost no lubricating properties for high-pressure applications such as crank bearings and cam followers.
Stuck closed causes a slight power loss. The PCV valve has one major function and one minor side-benefit: it allows crankcase oil vapor to be burned instead of venting to atmosphere and the vacuum applied to the crankcase reduces crankcase pressure slightly. Pistons moving up-and-down pump crankcase air as wells as intake air, using horsepower to do so. Reducing the crankcase pressure reduces pumping losses.
Your pinging has nothing to due with the PCV; if it's gunked up and not rattling, that's an indication of badly worn rings and valve guides.
Bruce in Houston
bahearn is offline   Reply With Quote
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 32 Oct 3rd, 2008 03:11 PM
96 pathfinder se pcv valve ? mckennaiii Truck & SUV 4 Nov 9th, 2003 03:51 PM
Can't remove PCV valve... dschrier B11/B12/KN13 82-90 chassis 17 Dec 27th, 2002 09:58 AM
Which way to loosen pcv valve... dschrier B11/B12/KN13 82-90 chassis 2 Oct 20th, 2002 11:21 PM
Help with pcv valve.. dschrier B11/B12/KN13 82-90 chassis 4 Jun 21st, 2002 08:39 AM
