I don't know if this will help, but here goes...
I had to drop a 1.5 crate engine from Japan into my ex's '88 Sentra after she killed the old mill. Was told to get a 5/16 freeze plug and plug the exhaust port in the 52A head which went through the head between cylinders 2 and 3, from the exhaust side to the intake side. I did that and got the engine running, but it was leaking antifreeze from the head and overheating. Found out there was a 3/32-inch hole next to #3 intake port which went into the water jacket, so I removed the manifold, put a self-tapping screw in the hole, ground out a small spot on the intake manifold to clear the screw, sealed the puddin' out of the intake gaskets, reassembled it and all was good.
And then the head gasket blew.
Later, taters; Off to a better place. Catch me there!
