Old May 5th, 2003, 03:13 PM   #1 (permalink)
SuperHatch
Christopher the Unready
Send a message via AIM to SuperHatch
EFI Conversion Kit for E16, who wants one?
Was thinking about marketing the EFI E16 Conversion Kit to you guys, what do you all think? If you want me to do it, I got to have enough support for it, it will probably run close to 400 to 500 because of the rarity of the manifold and the labor required etc. etc, what do you all think, would you buy it if I made it... Granted, all you would need to do is supply the fuel pump and make the connections *which would be convienetly marked... * if I get enough support, I will begin to make official orders for the kits... like over 10 people
1991 Nissan Sunny GS 4 door H/B British Spec (right hand drive)
-Currently has a GA16DE with an intake, and it hauls ass.
1968 Chevrolet Chevelle 4 door British Spec (right hand drive)
-3.9L 6 cyl with a 2 speed Powerglide automatic transmission
2007 Dodge Caliber SXT US Spec
-1.8L 5spd, Mopar Headder (no it didnt' make a difference, the car is still slow as all get out)
Currently in Wiesbaden Germany.......
SuperHatch is offline   Reply With Quote
Old May 5th, 2003, 08:27 PM   #2 (permalink)
Webfoot
Nissan Addict
Webfoot's Avatar
I dunno, tempting, but i'm still thinking Webber.
87 SE Sport Coup
81 Toyota Diesel Pickup Cough Cough
98 Durango SLT Plus 5.9L V8 Magnum
Webfoot is offline   Reply With Quote
Old May 5th, 2003, 08:30 PM   #3 (permalink)
fastpakr
Nissan Fanatic
fastpakr's Avatar
Weber cost me about $250 by the time it was all done, including a $60 distributor from eBay and a $30 used Weber. Unless you can find those deals again (I haven't seem them since), you're going to spend $300+ to get the Weber up and running. For the extra 100-200 you'd be better off with EFI if the system works decently. The Weber works decently and is better than stock, but the EFI system has many advantages (cold weather drivability, efficiency, total power under the curve, etc...)
84 Ford Bronco II 2.8
86 Ford Bronco II 2.9
86 Nissan Pulsar w/ Weber and CA distributor (gone, but not forgotten)
fastpakr is offline   Reply With Quote
Old May 5th, 2003, 09:35 PM   #4 (permalink)
BeEleven
just rattle can it
BeEleven's Avatar
Send a message via AIM to BeEleven
what's included in the kit
Why did I pick such a slow car?
1986 B11 Sentra with cRucial modz
BeEleven is offline   Reply With Quote
Old May 5th, 2003, 11:53 PM   #5 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
Send a message via ICQ to Crazy-Mart Send a message via MSN to Crazy-Mart Send a message via Yahoo to Crazy-Mart
Hey superhatch quote me on an ECU,wiring harness,MAF + all sensors needed but i already got the manifold that would be nice to have a prepared harness for my E15t swap... only missing thing would be the SAFC and the fuel pump wich ill get next week !!
Crazy !
Sentra Sport Coupe 87 Turbo
14.850@97.454mph
H&R Spring, 15psi, TMIC, 370cc, Nismo mount and pulley, Almasi tuned ecu...
Crazy-Mart is offline   Reply With Quote
Old May 6th, 2003, 02:39 PM   #6 (permalink)
SuperHatch
comp 100
maf 50
throttle body 50
harness 100
coolant temp sensor 20
labor 50
fuel pump 100
the fuel pump, coolant temp sensor are new, every thing else you get from a junk yard, it will be tested to make sure everything works before it is sold to the public!! it also comes with the carbon canister and coil. I'm including labor in there because it takes about 10 hours to set everything up to make sure it's right, (This is a no joke type thing when you've got to constantly test it out) for you guys to set it up it would take about 4... becuase you have to convert the fuel lines and just misc. stuff that...it would be a plug and play type thing... so you're looking at about 485 (includes shipping) pay half now to buy parts and then the other half upon completion (after you get it)... that's that!! ^_^ Lemme know and I'll start taking orders...
Old May 25th, 2003, 01:44 PM   #7 (permalink)
87SENTRASE
King of Porn
87SENTRASE's Avatar
Send a message via ICQ to 87SENTRASE Send a message via AIM to 87SENTRASE Send a message via Yahoo to 87SENTRASE
Carb 4 life or EFI?
I think it is great. I have purchased (4) carburetors from Nissan installed @ $1,300.00 a pop. Now the one I have is bad again. A used aftermarket carb will cost about/around $125-150.00, and a reman carb will set you back about/aroun $300-350.00, still install rates need to be discussed. I plan to go EFI soon. Besides I could have had a sweet motor swap too with all of the money I have waisted on usless carbs over the years. Carbs are the past and I had a choice between F/I or a carbed Sentra, my dad kept saying get the carbed one, boy was that a mistake. Because I plan to do a F/I motor swap the fact that it is going into a once carbureted car makes it just a bit more work because of the fuel pump type and the fuel tank. So I have to get a tank from a Pulsar or fuel injected Sentra now. gconway1@msn.com -Greg
87SENTRASE is offline   Reply With Quote
Old May 25th, 2003, 06:39 PM   #8 (permalink)
sunnyb11
Posts: n/a
I was wondering, is there any chances that the EFI conversion kit would work with my E13?
Edit:
If it does, mine will be the first EFI E13 in malaysia...heh..
Old May 26th, 2003, 12:16 AM   #9 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
should work but fueling will be way too much with the Ecu of the ga16de... youll have to lean it alot !!
Crazy !
14.850@97.454mph
Old May 26th, 2003, 06:45 PM   #10 (permalink)
87SENTRASE
King of Porn
87SENTRASE's Avatar
Post EFI stuff
Well really, just grab everything from the intake manifold foward from andy E16I along with the harness, ECU, go pedal cable, fuel tank, & pump and walla! You have all the parts, now just install them or pay a mechanic to do it! -Greg
Old May 27th, 2003, 12:08 AM   #11 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
that would be TBI... not EFI as in 4 injector and still would inject too much for the 1.3l
Crazy !
14.850@97.454mph
Old May 28th, 2003, 01:13 AM   #12 (permalink)
87SENTRASE
King of Porn
87SENTRASE's Avatar
Oops!
Sorry Mart, you are right. Oh, I'm just carb crazy!
Old May 28th, 2003, 01:33 AM   #13 (permalink)
malaysia_boy
if were to get a twin weber setup for a E16, what type is recommended?
i'm intending to put in a twin dcoe36...but any weber adapter for E16?
Greetings from malaysia!!!
http://www.angelfire.com/ego2/sunnyboy/sunny_side.gif
malaysia_boy is offline   Reply With Quote
Old May 28th, 2003, 09:58 AM   #14 (permalink)
sunnyb11
Posts: n/a
wait....u mean u can find an E16 here in malaysia? where you found it?
Old May 29th, 2003, 12:06 AM   #15 (permalink)
Crazy-Mart
Kick ass 1.5L / Mod
Crazy-Mart's Avatar
check the sticky thread into the E/Ca series just below the b11-12 section
Crazy !
14.850@97.454mph
