Hey guys, new here, surprise to see people still remember the B12/13. Here's my problem maybe u can help. Does anyone notice that ALL B12 with rear stock suspension seems to be lower then the front. I have a stock 89 2d and the rear suspension use to be even with the front. After several time of carry heavy load to the airport the rear sink more than 1 1/2 inch at least. I did the press and release testing method of the rear suspension and the rear doesn't rebound as fast as the front(not even close).........that is when I press and release the rear suspension the rear just stay down and move up very slowly unlike the front which rebound the instance that you release. Could it be the spring cause the rear spring seems to be smaller or it's just the shock? Thanks
me too my car has the same situation. Before i had the car it was my fathers and he had the trunk full of tools: saw,toolbox.
But i'm not worried about the rears it's the fronts. When i open my hood and i look at the strut tower i see that there's a little rust and chipping going on. And i also think that my shocks are seized they don't absorb anything. i push down on the hood and the sink the move. their like stiff
Dream of becoming the fastest naturally aspirated ga16de sentra in Quebec
btw. only the springs are stock. The front struts are tokico and the rear struts are gold in color and have no brand label. Both front and rear struts are about 5 years old at least.
Originally posted by nyit240 btw. only the springs are stock. The front struts are tokico and the rear struts are gold in color and have no brand label. Both front and rear struts are about 5 years old at least.
it aint the springs, its the car. mine too. eibach
springs and i had the front cut 1 coil. same thing
just lowwer.
: thenagain it could be the box that takes most of my trunk up. love them 12s
just lowwer.
I don't understand? What do you mean by " its the car "?? do you mean the body?suspension parts? etc...........
All Sentras seem to have this problem. My car is slightly lower in the back but the rear onm my dad's B14 is really low compared to the front. It's not your car it's ALL Sentras
I had a '93 Sentra Classic (B12)
Mom's got an '03 Altima 2.5S
Dad had a '98 Sentra GXE
Current "rides": 2000 Kona Caldera "Callie", 1996 Specialized Hard Rock "Betty"
b13 up seems to be fine but all b12 I see have lower rear. I think it's the rear shocks or springs. Could it be over years the spring begin to weaken and lost the strength to rebound back to it's original height or could it be the shocks.....hmm...??? My sentra use to have even front and rear....Anyway I will know soon cause I'm replacing the rear spring and strut in a couple of weeks
Originally posted by nyit240 b13 up seems to be fine but all b12 I see have lower rear.
Did you even read my post???
Originally posted by nyit240 b13 up seems to be fine but all b12 I see have lower rear. I think it's the rear shocks or springs. Could it be over years the spring begin to weaken and lost the strength to rebound back to it's original height or could it be the shocks.....hmm...??? My sentra use to have even front and rear....Anyway I will know soon cause I'm replacing the rear spring and strut in a couple of weeks
already did that it dosent change anything. even w/ lowering springs. I have eibach pro kit cut 1 coil in the front only and changed the all struts.
Originally posted by nyit240 Cutting spring is never a good idea except for looks like the HondaZzZzZz people
when you spend $200 dollars for lowering spring and it doesent lower like it should and the store wont exchange them them b/c there pricks. you make them work if you know how too. I dont recommend
cutting if you dont know what the hell yooure doing. but mine are fine. not to bouncie or nothing.
take a look at these pics there is no saging in the rear of my B12 see the b12 rear fender is made lower than the front fender giving the illusion that its lower in the rear when infact its not But to fix the illusion you can either cut the fender higher or you can just leave the rear high and cut the front coil (with lowering springs cutting a coil isnt bad racers cut performance springs all the time to get the exact hight and feel.) or you can put blocks in the rear like i did. i got 2" sprint springs and i put .5" raising blocks right above the bottom coil. It didnt change my handling one bit. but it looks great
perfect hight. Its all about fine tuning the cars stance. my sprint springs were $150 the blocks were about 10$ not bad .
ill take some more pics soon so you can see what exactly im talking about. The car does look diff now though i took all the FX off except for the front air dam. New side markers, white dash pulsar seats, . bunch of other stuff
Selling or parting out 89' sentra b12. email me jjvphotography@comcast.net $300.00 or best offer.
