Old May 21st, 2007, 11:17 AM   #1 (permalink)
format13
Help with diagnosing distributor/coil problem
Ok, so after much poking around and some searching on this forum, ive come to the conclusion that i need one of 3 things to get my 90 sentra running again:
-A coil
-A power transistor
-A distributer
The car is running off and on, getting me about 20 miles before just dying. No noises or backfires when its dying, it just all of a sudden wont accelerate.
I did an ohm check on the tranistor and coil and both checked out, well the coils resistance was at 1.2 (1.08 reccomended by Haynes) and i figured that was ok. So im thinking it is the distributer, can anyone tell me a way to check and see if it is that or a test?
Thanks!
format13 is offline   Reply With Quote
Old May 25th, 2007, 12:22 AM   #2 (permalink)
SENTRASER
SENTRASER's Avatar
Resistance value continuity [1]
DISTRIBUTOR ROTOR
IGNITION COIL
Resistance value between terminals d and e 0.7 ohms [2]
IGNITION WIRE
Resistance value less than 30k ohms
[1] Between input and output terminals
[2] Approximately
CHANGE THAT COIL! once it warms up, one of the wires spreads out and causes a no-run situation I bet.
1992 NX2000 hardtop black 188k
1989 Sentra 4WD wagon bought with 88,000, now has 90,500 and counting!
SENTRASER is offline   Reply With Quote
Old May 27th, 2007, 09:54 PM   #3 (permalink)
sportcoupe(turbo)
sportcoupe(turbo)'s Avatar
Send a message via MSN to sportcoupe(turbo)
well im pretty shure thats not a distributer problem b/c if you had that the car would not start at all because that sends the sparks to the mixture chamber, and i see that that the transister cheked out ok so i would think its the coil.
sportcoupe(turbo) is offline   Reply With Quote
Old Jun 5th, 2007, 11:57 AM   #4 (permalink)
format13
for anyone interested...it was the distributor. oil was getting into it through the back where the motor is, i took the old one apart and saw oil streaks on the spinning disk thing inside. so im guessing just enough oil would get on there to cause it to fail....
well its fixed!
Intermittent (no) starting problem Actionclaw S13 240SX 1989-1994 14 Feb 9th, 2006 08:33 AM
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
Sentra vibrations and other problem premk71 B15 2000-2006 8 May 13th, 2005 07:09 AM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Unusual problem solved Zen31ZR Z31 300ZX(T) 2 Feb 19th, 2005 07:45 PM
