Old Jan 9th, 2006, 07:42 PM   #1 (permalink)
Sam_87ZXT
Need help with my auto tranny
I need help with my 88 sunny 1.3 auto... it's the same auto transmission as in the 1.6. It is carbed. the car will acellerate in first gear. It won't swtich to second gear unless i am really fast and let off the gas. It won't switch to third unless i do the same thing.
Now i have taken the govener out. the gear is not stripped. I have a new gear i'd like to put on it but i cant get the stinking pin out. Argh. Any help would be appreciated. Thanks
Sam
Sam_87ZXT is offline   Reply With Quote
Old Jan 10th, 2006, 08:52 AM   #2 (permalink)
bob89sentra
GA16I Guy
bob89sentra's Avatar
Hi Sam,
The pin that holds the govener gear on is usually a roll pin, and should have a split on one side. If you stick the govener assembly on something like the jaws of a vise, and use a trensfer punch, or a broken drill bit, that is slightly smaller than the diameter of the roll pin, you should be able to "tap" it out with a hammer. Since you say that the gear on the govener looks fine, you should also check the cable linkage that goes from the throttle plates to the transmission. If it were out of adjustment, or broken, the transmission would think it was at full throttle all the time, and wait untill you hit a high RPM to shift. If it does not have a throttle to transmission linkage, you might have a broken or leaking vacuume modulator (never seen one on a Sentra though).
Bob
89 Sentra owner 9 years 205,000 miles and counting!
bob89sentra is offline   Reply With Quote
Auto tranny? fireeater SR-Series Engines (DE/VE) 11 Dec 10th, 2005 01:23 AM
90 sentra auto tranny kamaleon B11/B12/KN13 82-90 chassis 3 Nov 12th, 2005 02:51 AM
Pulsar 89 Swapping Auto Tranny To Manual Fire_Leon B11/B12/KN13 82-90 chassis 4 Sep 15th, 2004 05:00 PM
Auto and Manual Tranny Hooper0577 S13 240SX 1989-1994 3 Apr 23rd, 2004 08:26 AM
GA16DE Auto Tranny Compatibility Sunny GA16DE 1.6L Engine 1 Oct 25th, 2002 12:24 AM
