Old Dec 13th, 2005, 12:30 AM   #1 (permalink)
72courier
A strange engine swap
A quick background,
I acquired a small worktruck, a 1972 Ford courier.
The engine is seized; while perusing the junkyard ,I found a 1985 nissan 200sx that had a front end collision, yet the motor turned over easily and only had 90,000 miles on it. It is a turbo 1.8 with a 5 speed.
I pulled the motor & (manual) trans, with the entire intake and harness on the passenger side all the way to the computer.
I would like to put this motor in my truck.
Feel free to flame me, but if you could also answer my questions, I would appreciate it.
1) Is this engine computer set-up stand alone, or will I need to do modifications to make it work?
2) I noticed there was another harness running to the passenger side of the vehicle, will I need this?
3) are there any sensors/electronics I might have to jump (example vehicle speed sensor,emissions, etc?
4) are there any easy tricks for mild performance gains with this motor; or things to look out for?
It is a small engine, but so is the truck and it has 4.11 gears.
I figured with the 5 speed and the turbo, it should be fun to drive and economical too (for a truck , anyway)
Thank you in advance,
and if I can help in anyway, I am a professional welder, primarily in GTAW (TIG, Heliarc) of exotic metals Stainless,Titanium,Aluminum, Haynes, etc
Also Laser and Electron beam welding and a decent machinist (as a hobby)
Andy
72courier is offline   Reply With Quote
Old Dec 13th, 2005, 09:18 AM   #2 (permalink)
bob89sentra
GA16I Guy
bob89sentra's Avatar
Hi Andy,
I can't help you on the 1.8L turbo, but I like the Idea of the swap.
I had as my first vehicle a 78 Ford Courier P/U, and I could not pass emissions (in California), so I bought a conversion kit to convert it to propane. I drove that little truck everywhere, and I was sad to leave it behind when I moved to Colorado eight years ago.
I hope it works out for you, because that would be a cool little "Sleeper"
Bob
89 Sentra owner 9 years 205,000 miles and counting!
bob89sentra is offline   Reply With Quote
Old Dec 14th, 2005, 10:03 AM   #3 (permalink)
72courier
Thanks for the reply,
it is a nifty little truck, extremely overbuilt, should hold up for quite a while.
MODERATOR, I believe I posted in an area that isn't quite right, please feel free to move this post to a more appropriate section.
Darn newbies!
Old Dec 14th, 2005, 11:02 PM   #4 (permalink)
72courier
After some research it seems that this is a ca18et motor,
hope this helps for some tips/insight.....
Engine Swap 2wd ~ 4wd 4x4munster Pathfinder 0 Sep 27th, 2005 01:27 PM
Engine Swap 2wd ~ 4wd 4x4munster Truck & SUV 0 Sep 27th, 2005 01:19 PM
95 hardbody engine swap... eyeshyed Truck & SUV 5 Jul 6th, 2004 11:25 PM
turbo or engine swap ! viciousxp B13 91-94 chassis 14 Jun 1st, 2004 09:47 PM
'90 GA16I engine to '86 B11 swap work? BluEyes B11/B12/KN13 82-90 chassis 18 Sep 2nd, 2003 08:32 PM
