maxima 2004 brake problems - Nissan Forum
A34 2004-2008 2004+ Maxima
post #1 of 21 Old Mar 23rd, 2005, 11:09 AM Thread Starter
have a 2004 nissan maxima
at 26000 km they said my brakes are warped -the warranty only covers it u ntil 20,000km
after they resurfaced it the next day i was still experiencing shuddering at high speeds
again i called and was told theat it is due to overheating and they suggested it was my fault
now i am at 46,000 km
and i am told i have to replace the pads rotors and brakes at a cost of 1000$
there is 30% left
i think this is abnormal -i owned a maxima previously and i never had this happen
please ad vise
thanks
robert
robertkert is offline
post #2 of 21 Old Mar 23rd, 2005, 12:37 PM
Will work for beer
Go somewhere else for the brake work if you can't do it yourself. $1000 is INSANE for those things. The factory rotors are $110 each retail and pads are about $50 a set. so that's $320 for pads and rotors. laboe isn't but about an hour to replace all 4 corners, so there's $100. That's $420 total.
The factory brake pads have been known to be a little soft. they do great for grandma that likes dustless, noiseless brakes, but anyone that uses them more than that seems to have problems with it. before throwing your rotors away, pick up some good aftermarket brake pads- Performance Friction makes some- and install them. don't even bother turning the rotors- just put the new pads in and go for a drive, following Perf Friction's recommended bedding-in procedure.
then come back and let us know what you think.
Matt93SE is offline
post #3 of 21 Old Mar 23rd, 2005, 12:47 PM Thread Starter
ref maxima brakes
thanks for the quick reply i am in montreal canada are these pads available here ?
would you advise how i can locate them ?
should i try the second suggestion even if the dealer told me my discs are warped ?which is what he says was casued by overheating and it was my fault
post #4 of 21 Old Mar 23rd, 2005, 01:17 PM
Will work for beer
many times, what feels like warped rotors is actually uneven deposits from the pads.
the pads leave small amounts of material on the rotors, which is different in friction than bare metal.. so when it hits these spots, the brakes grab harder.. when it hits bare metal, they don't grab quite so hard.. so you get a pulsing feel in the brakes and people think they're warped.
do some searching online for the brake pads, and try calling your local auto parts and performance parts stores. usually they can get them for you at a decent price.
If not, give my buddy Edwin a call at http://raceshopper.com/ and he'll get you fixed up.
Matt93SE is offline
post #5 of 21 Old Mar 23rd, 2005, 01:44 PM Thread Starter
ref maxima
ok i called a local dealer -
he sells the pads you recommended but
he recomended i switch my discs for perforated discs and use wagner thermo qiet pads
he is going to get back to me with a price for this
as for your comment on the warping -it was the dealer that reported back to me that all 4 discs are warped
and i do get a pulsing feel at high speed braking
post #6 of 21 Old Mar 24th, 2005, 01:30 AM
Will work for beer
STAY AWAY from drilled rotors!!!!!
for what you're doing, drilled rotors would do more harm than good.
The Wagner pads are okay, but I would recommend going with something slightly more aggressive. the Wagner pads are much easier on the rotors, but they also don't have the heat capacity the PF pads do.
Matt93SE is offline
post #7 of 21 Old Mar 24th, 2005, 09:41 AM Thread Starter
hi
is drilled rotors and drilled discs the same thing ?
sorry for my ignorance
they said they were putting perforated or drilled discs
they never mentioned rotors
post #8 of 21 Old Mar 26th, 2005, 12:35 AM
Nissan Addict
Yes, rotors and discs are for (stock brakes) interchangeable terms.
As Matt said, DO NOT use drilled rotors!!
brianw is offline
post #9 of 21 Old Apr 12th, 2005, 06:29 PM Thread Starter
ref maxiam 2004 pads
ok i followed your recommendation and ordered the performance friction pads
the brake shop justcalled and what they received was
APPLICATION ENGINEERED PREMIUM DISC BRAKE PADS /CERAMICS /SELECT FUNCTION TECHNOLOGY
this is what NAPA sent him when he ordered the one i asked for -
are these exctly the same ?
why would they do a switch then ?
let me know bfore i have them installed
thanks
robert
post #10 of 21 Old Apr 12th, 2005, 06:30 PM Thread Starter
maxima 2004 pads
thanks
robert
post #11 of 21 Old Apr 14th, 2005, 06:29 PM
Send a message via MSN to Baddad
Great advice gents.....but remember, re-surfacing warped rotors is a waste of time and money. By the time they are warped, they are ruined.
Baddad is offline
post #12 of 21 Old Apr 14th, 2005, 07:08 PM Thread Starter
maxima 2004
so you recommend i change them
hve you encounterd this problem with yur maxima ?
post #13 of 21 Old Apr 15th, 2005, 11:48 AM
No sir, I haven't had this problem with my Maxima. It's an 05' and I only have 6K on her so far. I've owned Acura's, CRX's, 510's, Porsche's and just about every US manufacturer and have worked for brake shops in the past. I have found that when a rotor is warped, you can re-surface it and it will be fine until it heats up again and again and eventually it will retain its warped state. Allot of the times, you can use your original pads (personally, since I'm in there, I would replace the pads also). Buy yourself a good quality rotor and try not to ride on the brakes too much. I do not think this is an across-the-board problem with Maxima's.
I'm sure there are allot of folks in here better qualified to answer this or give their opinion on this topic, I'm just speaking from experience and for what's it's worth....I'd say I have only about 50+ brake jobs under my belt.
Good Luck my friend,
Craig
Baddad is offline
post #14 of 21 Old May 4th, 2006, 09:37 PM
We have a 2004 Maxima. In January of this year we had front rotors turned and pads replaced at 74500 miles. This became an apparent need when after pulsating for a while we began to hear metal against metal sounds. Four weeks after the rotors were turned, we began to feel the pulsating return. Now at 85000, it is becoming dangerous to get the car in tight situations as the pulsating makes it hard to control the car. Our mechanic tells us it is because the back brakes have a problem of some sort with the caliphers which causes the front brakes to do most of the work, which brings an overheating situation and warps the rotors again. He says there is some sort of problem with the brakes on this particular model. Is that true? If so, how do we get this corrected. BTW, we put approximately 100 to 150 a day, mostly highway driving on this car.
LindaGene is offline
post #15 of 21 Old May 6th, 2006, 12:50 AM
I had warped discs on a 2000 maxima at 30000km. I was told they would replace for 300-400cdn dollars as they were no good anymore.. I said BS and fought dealer. They said I must drive it like some kid booting a TC grand Prix. Bloody cheek of them.
They told me they would machine them down. No blooming way I said. I sell castings and I know these are faulty castings. Soon again warp would come back.
Eventually they said they would replace free. I never checked to see if they were
honest !!! You gotta fight the bastards or they will walk all over you. The same car had tranny failure, tranny replaced but problem still existed --solenoids ?? Found a hidden warranty. Dealer knew nothing !! usual dumbness !!. They spent 10,000cdn dollars warranty on my car. However i traded for a 02 model.Yes an other Maxima 02 , which broke down at 800kms. Chip problem !! Listen up, I now have a 04 model!!!
A sucker for love.
Overall I like performance-to-cost ratio.
interalia is offline
  Nissan Forum > Maxima > A34 2004-2008
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
2004 maxima with elite package pricing AR-15 A34 2004-2008 1 May 1st, 2004 01:13 PM
Brake problems luis_pty Z31 300ZX(T) 1 Apr 26th, 2004 12:15 PM
brake problems Adrian Z31 300ZX(T) 6 Apr 18th, 2004 12:32 AM
New Big Brake Kit-Test Fit YOUR Wheels on my car at Sunday's meet kwd2kSE Houston Nissan Enthusiasts 2 Dec 14th, 2003 12:37 AM
You may post new threads
You may post replies
BB code is On
