Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Mar 4th, 2005, 03:59 PM   #1 (permalink)
RLee
2000 Maxima GLE, Help, Service Engine light on. 2000 Maxima
I have a Service engine light on. The fault code is PO174, bank 2 to lean. Had this fault before (0171, Bank 1 to lean) 6 weeks ago.
RLee
RLee is offline   Reply With Quote
Old Mar 4th, 2005, 08:15 PM   #2 (permalink)
am3rican
Banned
Send a message via AIM to am3rican
RLee
You have a number of options here. If your sensors say your running lean, chances are there is a problem with your fuel system. This happened to me all the fu**ing time when i owned a DSM (91 Plymouth Laser). Try running a fuel treatment system like STP in your car because it could be just a plugged fuel injector. Try the STP type stuff first because if its saying you are running lean multiple times you might just have carbon build up that needs to be taken care of. Also, it might just be a faulty o2 sensor which just means you need to replace it. try all these other remedies first and then take it to your mechanic. and...run 93 octane.
http://www.valvoline.com/pages/produ...asp?product=54
am3rican is offline   Reply With Quote
Service engine light..how do I reset it in my 2003 Maxima? remphish1 General Maxima Discussion 3 Nov 15th, 2004 12:46 PM
2000 Altima Service Engine Soon aac L30 1998-2001 Altima 5 Jun 10th, 2004 05:38 PM
Service Engine Light iguerra770 L30 1998-2001 Altima 1 Feb 17th, 2004 04:23 PM
Service engine soon light; Timing chain cover tedrik13 GA16DE 1.6L Engine 8 Feb 8th, 2004 02:08 PM
how to clear the check engine light on a 96' maxima mxxmikexx New Member Forum 6 Nov 11th, 2003 04:06 PM
