Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Feb 5th, 2004, 05:18 PM   #1 (permalink)
ped
2000 Maxima - engine knocking
I'm hearing some knocking under acceleration in my 2000 Maxima SE. What causes this (I'm using good premium gas)? I haven't had the official 45K tuneup but oil and air filter have been done recently. And hearing part of what goes into the 45K tuneup I'm not convinced they do much to the engine then anyway. How can I fix this without spending lots of monet and what's causing it?
ped is offline   Reply With Quote
Old Feb 5th, 2004, 06:24 PM   #2 (permalink)
Sanyo
Nissan Fanatic
Sanyo's Avatar
Send a message via AIM to Sanyo
Have you advanced your timing at ALL? Or messed around with your engine alot? Also I know you said you changed the oil (or had changed) but did you actually check the oil level a few days after? A friend of mine was due for a oil change in like 1k miles, but to his suprise, after his engine started knocking there was no oil in it. Ruined a Oldsmobile Aroura that way, had a V8 32valve 4.0 cadillac northstar engine that way. I know that prolly isn't it but it was time for a story
I like my women like I like my coffee, ground up and in the freezer!
Sanyo is offline   Reply With Quote
Old Feb 5th, 2004, 10:45 PM   #3 (permalink)
ped
I have done nothing to the engine - it';s fully stock. And I just had the oil changed today, and the engine was knocking on the way home if I got on the gas more than a tiny bit.
Old Feb 6th, 2004, 01:54 AM   #4 (permalink)
mrRICEguy
Send a message via AIM to mrRICEguy
even though u just got ur oil changed, check and make sure theres oil in ur engine just to be on the safe side
ga16det comin soon....
mrRICEguy is offline   Reply With Quote
Old Feb 6th, 2004, 11:20 AM   #5 (permalink)
ped
Ok, so assuming oil is OK what could cause the knocking? WOuld only bad gas cause this? How about clogged injectors? I'm thinking I'll baby it to minimize occurrence until this tank is empty (water in gas, bad gas etc) then I'll fill it with super premium and run that and see if it clears up. Does this sound like a good plan to you guys or should I take it into the shop right away?
Old Feb 7th, 2004, 05:57 PM   #6 (permalink)
charliekilothree
You might be experiencing the dreaded ignition coil(s) failure. They are prone to failure on the 2k Max.
charliekilothree is offline   Reply With Quote
Old Feb 7th, 2004, 09:48 PM   #7 (permalink)
ped
Is that covered under the engine/tranny 5 yr/60,000 mile warranty?
Edit: I see that it's not and as you implied it appears to be a common problem with the 2000 Maxima.
Any idea how hard it is to do this? Should I just find the best price I can on 6 of these and do them myself?
Old Feb 8th, 2004, 10:25 PM   #8 (permalink)
maximadave
maximadave's Avatar
Send a message via Yahoo to maximadave
2000-2001 Maximas have a problem with their coil packs and is under a TSB.
check with your Nissan dealer (sorry I don't have a copy of the TSB)
2002 NISSAN MAXIMA SE 6-SPEED
SALES AND LEASING CONSULTANT
QUALITY NISSAN - TEMECULA, CA
(909) 676-6601
(800) 695-8106
http://www.qualitynissan.com
maximadave is offline   Reply With Quote
Old Feb 10th, 2004, 12:33 PM   #9 (permalink)
ped
Is this a difficult thing to do? It sounds easy but I'm not even close to being a mechanic.
Old Feb 10th, 2004, 03:29 PM   #10 (permalink)
cutlr7
Coils are very easy to change! If you have any questions, email me.
cutlr7 is offline   Reply With Quote
Old Feb 10th, 2004, 04:27 PM   #11 (permalink)
Ridge_Racer
Send a message via AIM to Ridge_Racer Send a message via MSN to Ridge_Racer
Originally Posted by cutlr7
Coils are very to change!
Bucky the HIPAA Beaver OWNZ JoO!
Going thru MAXIMA.ORG withdrawl...
Ridge_Racer is offline   Reply With Quote
Old Feb 10th, 2004, 04:43 PM   #12 (permalink)
cutlr7
Its a Hippo Bish :dumbass:
what is the engine code for the 1998 se maxima S15 SR20DET A32 1995-1999 Chassis 10 Apr 2nd, 2004 06:47 PM
Service engine soon on 2000 Frontier? thenewfrontier Truck & SUV 7 Mar 29th, 2004 08:48 AM
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 10:09 AM
2000 Maxima Bumper SRNSCALI New Member Forum 4 Jul 1st, 2003 05:19 PM
considering a maxima engine niky GA16DE 1.6L Engine 9 Sep 28th, 2002 10:09 AM
