» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Jul 2nd, 2009, 07:45 PM   #1 (permalink)
BernieK
Alternator substitution, '92 Max on 2000 Max
Hi. 2000 Maxima, 66K miles: Have an intermittent charging condition. Started today after WOT to redline (auto trans). Battery light came on, as did dim brake light (proper for alternator failure). Got home after 1/2 hour with battery voltage down to 11.7V. 80A fuses and 120A fuse were fine. Charged battery. Started engine. No battery light on. Drove at WOT, 1-2 and 2-3 shifts a few times, and saw the battery light flicker once. So, it appears that the alternator is intermittent.
From what I've read, the internal voltage regulator is probably not the problem as it will not illuminate the battery light. I'll remove the alternator and check for bad solder joints on diodes, stator connections, brush holders and such. Any suggestions would be appreciated.
However, I do have a spare alternator from a former '92 SOHC Maxima. I'd like to use it if possible. Mounting considerations are the major considerations. If the B and S connector(s) are different I'll do an adaptation. Again, any information would be appreciated.
Please PM me and if possible, please copy to berniek@technicaldevelop.com.
Thanks. Really appreciate this forum.
BernieK
BernieK is offline   Reply With Quote
Old Jul 5th, 2009, 09:37 AM   #2 (permalink)
Outkast
Nissan Fanatic
Send a message via AIM to Outkast
Do not do that. The 92 alternator was engineered for less of a load then the 00 one is.
Mmm Mmm Boost, It's what's for dinner!!
Outkast is offline   Reply With Quote
