Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Dec 28th, 2007, 03:57 PM   #1 (permalink)
rhino_160
01 Maxima problem- mainly at Idle
hey all, 2001 Maxima SE. when it is cold outside and you first start it up, it will idle a little rough. it is not to the extreme like it is going to die or anything, but is just a little rougher than normal. once you put it in drive and go, the next time you stop, it idles just fine. so it is basically at the first start up, but once warmed up, it is good. any ideas? thanks
rhino_160 is offline   Reply With Quote
Old Dec 28th, 2007, 08:04 PM   #2 (permalink)
birdsflyingover
well, it may just need and injector cleaning service or top engine clean(seafoam). if you are fairly competent you can buy seafoam and do it yourself, but you can cause serious damage if it not done correctly.
also the coolant temp sensor may be defective but unless you have a dvom meter you will not be able to check it. if you do i can get the specifications for you. i think the cold start circuit is not on these newer maximas but you can check your fuses for a blown "start circuit" fuse.
i don't suspect the fuel filter as the culprit but's always a good idea to replace it every 30k or so to prevent such things like clogged injectors and a higher strain on the fuel pump.
birdsflyingover is offline   Reply With Quote
Problem with Engine Idle Speed - Unstable. X-Trailer X-Trail 27 Nov 10th, 2005 06:57 PM
Maxima Clutch fade problem...again ( Long) terrys A34 2004-2008 7 Sep 1st, 2005 11:16 PM
93 Maxima ECCS Relay Problem sun_123 J30 1989-1994 Chassis 0 Jan 27th, 2005 02:39 PM
92 nissan pickup Idle problem 92nissanpickup Truck & SUV 11 Nov 3rd, 2004 09:36 PM
