Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Sep 5th, 2007, 09:51 PM   #1 (permalink)
01maxi
Question 01 maxima engine missing, rough idle, no power at low RPM'S
Hi all, This car has 107,000 miles on it. Finally changed the oil after the oil level was real low probably only a cup in the crank case. Installed new spark plugs and verified spark from each coil, but the car still seems to miss - no backfire and Advance Auto says it's showing a miss fire in one of the cylinders - no dah... I should mention the problem started just before I changed the oil. Put injector cleaner in it - no help. The car has "Check Engine Soon" light on. Probably O2 sensers on that one. What about the EGR Valve? Or injector bad? I'm out of ideas, can you suggest anything? Thanks.....
01maxi is offline   Reply With Quote
Old Sep 6th, 2007, 04:48 PM   #2 (permalink)
JNCoRacer
G String Money Tight
JNCoRacer's Avatar
Send a message via Yahoo to JNCoRacer
Coil pack possibly? Try switching the coil packs or unplugging the one on the missfiring cylinder and see if theres a difference.
JNCoRacer is offline   Reply With Quote
Old Sep 6th, 2007, 09:18 PM   #3 (permalink)
metro273
Nissan Technician
metro273's Avatar
'00 and '01 Maximas are notorious for these symptoms! The problem is with one or more of the coil packs. If you get a specific cylinder code, then your in luck. If you get a P1320, Primary Ign Signal, then it can be either of the 6 coils!
Wishing I was in Sunny Florida!!!
metro273 is offline   Reply With Quote
Old Dec 18th, 2007, 08:00 PM   #4 (permalink)
wills00max
Yup same issue here dude, frustratin when ya give it gas and does absolutely nothing. Ordering new set of coils from nissan within the next couple of weeks, hopefully dat resolves this issue.
wills00max is offline   Reply With Quote
Rough idle in the cold eddy_75165 HB Truck 7 Apr 12th, 2007 01:33 PM
Low engine compression - only 80K miles on the engine suleozev General Maxima Discussion 1 Oct 25th, 2005 08:41 AM
Bad Gas Mileage 1997XETruck Truck & SUV 48 Sep 5th, 2003 02:35 PM
1997 2.4L rough idle in drive w/ AC on larrymoencurly Truck & SUV 9 Jul 24th, 2003 09:57 AM
Rough Idle / Engine Light On Thrasher Truck & SUV 3 May 8th, 2003 06:29 PM
