Hi all, This car has 107,000 miles on it. Finally changed the oil after the oil level was real low probably only a cup in the crank case. Installed new spark plugs and verified spark from each coil, but the car still seems to miss - no backfire and Advance Auto says it's showing a miss fire in one of the cylinders - no dah... I should mention the problem started just before I changed the oil. Put injector cleaner in it - no help. The car has "Check Engine Soon" light on. Probably O2 sensers on that one. What about the EGR Valve? Or injector bad? I'm out of ideas, can you suggest anything? Thanks.....
