Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old May 14th, 2007, 05:51 PM   #1 (permalink)
crispy476
2001 Power steering question
I have searchd and came up with nothing...
I want to flush the system, and on the reservior there are two hoses (small, large) I am looking to verify which one is the supply and return hose.
I believe that the large line is the supply and the small is return ( just like in a HVAC system (water) you always restrict the leaving side to keep the coil full of liquid)
Am I correct in my thinking?
Also, about how much capacity does this system have?
Thanks
Chris
crispy476 is offline   Reply With Quote
Old Jun 16th, 2007, 03:09 PM   #2 (permalink)
kmr16442
I just replaced the power steering hoses on a 2000 Maxima. The large hose coming off the bottom of the tank provides fluid to the power steering pump.
I used about 3/4 of a quart of fluid to fill the system. Once you drain the fluid you'll need to bleed the system.
It is real easy- Fill up the tank and then jack up the front wheels so they are off the ground a little. With the engine off turn the steering wheel slowly from side to side about 5 times .Check the fluid level, it should have gone down some. Top off the tank and repeat the procedure one more time.
Leave the wheels off the ground and start the engine and turn the wheels another 5 times or so. Check the fluid level and top off if necessary.
kmr16442 is offline   Reply With Quote
Disabling Power Steering on '91 240SX snunes S13 240SX 1989-1994 4 May 15th, 2005 04:50 PM
2000 Fronty Power Steering problem stevem5000 Frontier 1 Apr 27th, 2005 08:35 PM
power steering pulley question Bosco Truck & SUV 0 Feb 15th, 2005 10:45 AM
Another question: power steering fluid sinepi A32 1995-1999 Chassis 4 May 2nd, 2004 09:34 PM
