Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Jul 6th, 2006, 02:37 PM   #1 (permalink)
Orange E
Red face O1 Maxima Wheel Bearing Advice
I own a 2001 Maxima GLE with 101K. I think the right wheel bearing is bad. Has anyone tried to replace one or both sides on your own? The wheel bearing itself is around $50.00 from Napa.
I'm considering doing it myself if it's not too difficult. Any helpful advice would be greatly appreciated.
Orange E is offline   Reply With Quote
Old Jul 6th, 2006, 05:17 PM   #2 (permalink)
Matt93SE
Will work for beer
the bearing is common to go out on these. unfortuantely 90% of the time, they will ruin the wheel hub as well when they go out.. so you'll need to replace both pieces.. Wheel hubs are dealer-only and run about $130, then another $35 for the bearing.
half the time, I just get an entire used spindle/knuckle assembly from the junkyard for about $50 and bolt it in. if the bearing is still good on it, then the hub will be too. just buy a new bearing and replace the bearing in the other used (but good) spindle and you're out a total of about $100.
tools required are regular hand tools to remoe the spindle, plus a hydraulic press to smash in the wheel bearing. not something you can do with a bench vice. pressing in that bearing stresses my 12 ton hydraulic press pretty good.. If you don't have one, then you can basically get all the parts off the car and ready to be swapped, then take it to a mechaic/machine shop and hand them a $10 to press the bearing in for you. cheap and easy.
My website.
Old Jul 8th, 2006, 04:56 PM   #3 (permalink)
Orange E
01 Max Hub removal help
Matt,
That all sounds reasonable but I'm having issues getting the hub off. I have no problems getting the axle nut off, but I was hoping the hub would slide off, but it doesn't. The axle can be moved back in forth. Is something else suppossed to be removed to get the hub off or does the entire spindle have to be removed?
Old Jul 10th, 2006, 10:32 AM   #4 (permalink)
Matt93SE
Will work for beer
the entire spindle has to be removed. the hub is pressed into the wheel bearing, which is pressed into the spindle as well.
so you have to pull the whole spindle and press the wheel hub out, then remove some retaining clips from the spindle (dig around in the grease and you'll see them), and finally you can press out the wheel bearing.
My website.
Old Jul 11th, 2006, 09:28 AM   #5 (permalink)
Orange E
Matt,
Thanks for the reply; yeah I figured that out. My neighbor who was out of town is a mechanic and said basically the same thing. If anyone is interested I found a factory service manual for my 01 Max; it's in PDF. It shows step by step how took replace the front wheel bearing.. It's pretty good; I'm glad I found it.. I just ordered a tie rod end ball joint remover from JC Whitney; it's the type that won't tear the boot. I couldn't find it locally. As soon as that comes I should be able to take the spindle off. I'll just take the whole thing to a shop and have them press the old bearing out; if the hub is good I'll just have them press the new bearing in. I'm hoping I won't have to fork out $150 for a new hub too, but I will if I have to. I'm a little surprised to see the bearing go bad at 101K; although I've read in some other forums of front bearings going bad much sooner; some as soon as 30K...
Thanks again...
Wheel bearing??? latenightcustom U13 1993-1997 Altima 5 Jan 1st, 2006 12:39 PM
Bad Wheel Bearing or not SUPERFLYNISSAN200SX B14 95-99 chassis 15 Aug 18th, 2005 11:00 PM
tranny oil, LSD gear oil, front wheel bearing greese swammer Pathfinder 1 Aug 3rd, 2005 09:46 PM
Wheel bearing or hub bearing... dschrier B11/B12/KN13 82-90 chassis 5 Oct 20th, 2002 09:34 PM
Need wheel bearing.. Mike92se B13 91-94 chassis 2 Aug 29th, 2002 01:19 AM
