Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Maxima > A33 2000-2003 Chassis
Old Nov 14th, 2005, 06:24 PM   #1 (permalink)
max556
Idle problem
For some time now, my idle simply dies. Cold or warm engine it suddenly dies.
I looked for anything wrong or disconnected, removed and cleaned the IACV
and motor, nothing helped. Sometimes it does it more often than others.
I think it happens more often when warm, but I am not sure.
Above 1100RPM it works fine. At idle if I am quick and hit the gas when it starts dying, it picks up and runs like everything is ok, a few seconds later it may suddenly die.
Please help, It can't continue like this.
max556 is offline   Reply With Quote
Old Nov 15th, 2005, 01:44 AM   #2 (permalink)
brianw
Nissan Addict
Send a message via ICQ to brianw Send a message via AIM to brianw
Sounds like a loose vacuum hose.
brianw is offline   Reply With Quote
Old Nov 15th, 2005, 09:37 PM   #3 (permalink)
max556
If it is, it is well hidden. I have checked for vacuum leaks.
I do see the need for a more carefull inspection. This weekend
I'll go through with a fine tooth comb.
Any other possibilities?
Thanks.
Old Nov 16th, 2005, 02:41 AM   #4 (permalink)
PathFinderDriver06
Send a message via AIM to PathFinderDriver06
Does it starts from the first time?
Or sometimes you have to start it twice?
and what year is your max?
PathFinderDriver06 is offline   Reply With Quote
Old Nov 16th, 2005, 06:53 PM   #5 (permalink)
max556
It starts right away every time.
It is a 2000, the problem is intermittent.
I have good days and bad days where I have to restart constantly.
Old May 15th, 2006, 01:10 AM   #6 (permalink)
Carp12000
did you fix the idle ?
im having the same problem right now, my car is doing the exact same thing your describing and its a 2000 if you found out what was wrong let me know because i cant find whats wrong with it
Carp12000 is offline   Reply With Quote
Old Jul 2nd, 2006, 06:32 PM   #7 (permalink)
mang0
You need to have the computer readings from a Nissan dealer; you could have an intake air leak- a bad AIrflow meter -a bad throttle air regulator some of them leak antifreeze in the intake and short out the ECU also.
mang0 is offline   Reply With Quote
RPM Idle problem EP240SX S13 240SX 1989-1994 3 May 25th, 2005 03:21 PM
idle problem - E16s winstonsmith E/CA-Series & GA16i Engines 13 May 11th, 2005 01:01 PM
HELP 96 Nissan sentra problem with idle trav6612 B14 95-99 chassis 14 Apr 15th, 2005 09:56 AM
Idle problem, IAA Valve? K-1 S13 240SX 1989-1994 4 Jan 31st, 2005 09:36 AM
1990 Idle problem yoderconsult GA16DE 1.6L Engine 1 May 23rd, 2004 10:21 AM
